Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
  • 1.  Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
    Posted Mar 27, 2014 07:52 PM
    While implementing ClearPass guest with a Cisco WLC on 7.6 we encountered a problem. Basically it didn't work :)
    The solution worked fine without MAC-caching, but for guests having to re-login all the time it's not ideal so thats why we wanted MAC-caching. So we implemented the more or less your MAC-filtering with captive portal fallback.
    When connecting any unknown client we just got "Could not connect to the network", and saw this in Access Tracker:
    2 seconds between re-tries, and for some reason the WLC ignores the captive portal fallback and just drops the client instead of redirecting.
    I doubt that it's expected behaviour from the WLC, but still had to try to find a way around it.
    Alot of googling and testing later gave cause to adjust the Radius Reject delay
    ==> Administration » Server Manager » Server Configuration || Radius Server || Reject Packet Delay = 1
    Changed this value to 0 and it started working instantly. We changed it back and forth between 0 and 1 while changing some timing values on the WLC etc, but ended up just leaving it at 0.
    If setting this to 0 has any other nasty consequences is yet to be seen, but if any of you guys have any experience with this and have a better solution then please let me know.
  • 2.  RE: Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
    Posted Jul 13, 2014 05:42 PM
    A quick google search will show that others have had this same problem with Cisco in the past.  Even in an all-Cisco environment (including ISE) there were problems with MAC On-Failure processing.  I don't know if they came to the conclusion about the Reject Delay setting, but it works with Aruba ClearPass.
    Thanks John for the post.
    Richard.
  • 3.  RE: Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
    Posted Jan 25, 2017 04:07 AM
    Further to this and for my own benefit when I revisit much later, I had to do the following.
    MAC Filtering --> Radius Compatibility = Cisco ACS
    Radius Authentication Servers --> Call Station ID Type = System MAC Address
  • 4.  RE: Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
    Posted Apr 09, 2018 11:55 AM
    Can you explain why you would choose colon over hyphen for delimeter?
    Chris
  • 5.  RE: Trick to get MAC Caching working on Cisco WLC 7.6 with ClearPass
    Posted Apr 09, 2018 12:13 PM
    Hi!
    Clearpass doesn't care if it's Hyphen og Colon (unless you specificy this in your policy), but just use the same on both settings.
