Trouble adding BW contract, cant find where to add it.
  • 1.  Trouble adding BW contract, cant find where to add it.
    Posted Apr 09, 2014 06:05 AM
    I'm trying to set up a per user policy BW policy. Since we are having trouble with a few users using most of the bandwith.
    Right now I'm trying to set up a BW contract according to the aruba manual, but can't get it to work.
    I can create a BW contract without problem, but having trouble appling it to the enviroment.
    The trouble i'm having is i cant find out how to add the BW contract to a user role. Or if its supposed to be added somewhere else, but since i'm not that at home with aruba, im trying to follow the manual. But when i follow the manual I can't get it to work, maybe i missed something obvious.
    It's an aruba 3200 with arubaos 6.1.3.6
    This is what I see on the webgui, at first no edit button only a view button, then when i click view i can change some properties but not any BW contract properties.
    #3200
  • 2.  RE: Trouble adding BW contract, cant find where to add it.
    Posted Apr 09, 2014 08:19 AM
    If there is only a view button; check whether you have the PEFNG license?......are you logged into a local controller?....Do you have root access or read only?
    It should be listed under Role VLAN ID within the user role configuration:
    In newer AOS versions, it is on the Bandwidth Contracts tab within the role configuration:
    It doesn't look like yours is showing this.  Can you try another browser or delete your cache on that browser and try again?
  • 3.  RE: Trouble adding BW contract, cant find where to add it.
    Posted Apr 09, 2014 08:31 AM
    Checked the licences on the aruba and the PEFNG licence is missing. Thanks =)
