trouble connecting acer iconia 10 tablet to aruba
  • 1.  trouble connecting acer iconia 10 tablet to aruba
    Posted Apr 03, 2015 02:09 PM
    We have some Acer Iconia 10 Tablets running Android 4.4 and they have issues with Authenticating through clearpass on both our SSID with PSK and our Authentication rules for wireless devices, i wondered if anyone else has run into the same issue and if there is a fix? we did a factory eset and even updated the firmware on the Android Tablet with no luck, we can connect to the Guest Broadcast without a problem.
    When connected to our Test enviornment Cisco Linksys router it jumps between WEP and WPA/WPA2
    I would like to get any insight into this problem if it has been encoutered anywhere else and if there is a solution?
  • 2.  RE: trouble connecting acer iconia 10 tablet to aruba
    Posted Apr 04, 2015 09:48 AM
    Unless someone responds with something specific about the Iconia 10 Tablet, we need much more information:
    - What version of ArubaOS?
    - What access point?
    - What type of encryption is being used?
    - Did you enable client debugging to see where it fails?
  • 3.  RE: trouble connecting acer iconia 10 tablet to aruba
    Posted Apr 06, 2015 01:03 PM
    - What version of ArubaOS? Aruba 7210 Ver.6.3.1.14
    - What type of encryption is being used? tried 802.1x and PSK- Works on Guest open SSID
    - What access point? AP-225
    - Did you enable client debugging to see where it fails? We did not try any debugging, We have since send back the Tablets to get a different manufacturer.
    My question is if we have vendors or guest come in and we have issues witht those devices, what can we do?
    #7210
