last person joined: 11 hours ago
Trouble uploading firmware to AirWave
  • 1.  Trouble uploading firmware to AirWave
    Posted Mar 30, 2020 10:06 AM
    Recently upgraded AirWave to 8.2.10.1. Now trying to upload IAP 305 and 315 firmware version 8.6.0.3-8.6.0.3_74788 to AirWave and not having any luck - AirWave web UI becomes unresponsive and requires refresh when I try to upload over a network drive using HTTPS.
    Any suggestions on how to overcome this?
  • 2.  RE: Trouble uploading firmware to AirWave
    Posted Mar 30, 2020 10:48 AM
    This worked OK for me. You don't have to select HTTPS. Just leave it Aruba device (any) and then leave it as TFTP. After the upload, it will change it to HTTPS. The screen did go blank but after a refresh, it did show the file there.
  • 3.  RE: Trouble uploading firmware to AirWave
    Posted Mar 30, 2020 10:59 AM
    OK, problem solved - root cause: user impatience.....needed to wait a little longer.....files now uploaded to AirWave OK.
    Thanks for the response, Seth.
