Wired Intelligent Edge
last person joined: 5 hours ago
Trouble with wired captive portal on central with 2930m
  • 1.  Trouble with wired captive portal on central with 2930m
    Posted 14 days ago
    Hey,
    I'm trying to do a captive portal failthrough for clients at our branch sites. Running AOS 10.3.1.3 on the gateway and 16.11 on the 2930m switch, managed via UI group on Central. When I give it a VLAN, session timeout and nas-filter-rule everything is fine and it authenticates.
    The ACL I'm giving it is allow all to clearpass (where the captive portal lives), DHCP, and DHS. The VLAN is a bridged VLAN, so it goes in the underlay. On the BGW, I have an full-tunnel PBR associated with that VLAN so all traffic routes into the overlay. I've take some debugs when I add the captive portal attribute which is the following: Radius:Hewlett-Packard-Enterprise:HPE-Captive-Portal-URL = <captive portal URL https://... in clearpass>
    Everything works until I send that RADIUS attribute back as well and then I get this error:
    0002:23:29:43.88 MAC  eDrvPoll:Port: 3 MAC: 3448ed-47bfee rejected during demux,
       known unauth client.
    0002:23:29:42.88 MAC  mWebAuth:Port: 3 MAC: 3448ed-47bfee client authentication
       failed, login retry count: 1 >= max-retries: 0, no unauth-vid configured,
       entering quiet-period: 60 seconds.
    0002:23:29:42.88 MAC  mWebAuth:Port: 3 MAC: 3448ed-47bfee client rejected,
       session: 271, invalid attributes.
    0002:23:29:42.88 MAC  mWebAuth:Port 3, MAC 3448ed-47bfee: Captive Portal
       attribute validation error.
    0002:23:29:42.87 RAD  tRadiusR:Removing RADIUS REQUEST id: 247 from queue.
    0002:23:29:42.87 RAD  tRadiusR:ACCESS ACCEPT id: 247 from 10.146.22.12 received.
    0002:23:29:42.86 MAC  eDrvPoll:Port: 3 MAC: 3448ed-47bfee rejected during demux,
    0002:23:29:42.83 RAD  mRadiusCtrl:ACCESS REQUEST id: 247 to 10.146.22.12
       session: 271, access method: MAC-AUTH, NAS-identifier: 28301-sw-01.
       session: 271, access method: MAC-AUTH, User-Name: 3448ed47bfee,
       Calling-Station-Id: 3448ed-47bfee, NAS-Port-Id: 3, NAS-IP-Address:
       10.136.20.130.
    0002:23:29:42.83 RAD  mRadiusCtrl:Received RADIUS MSG: DATA, session: 271.
    0002:23:29:42.83 RAD  mRadiusCtrl:Received RADIUS MSG: AUTH REQUEST, session:
       271, access method: MAC-AUTH.
    0002:23:29:42.83 MAC  mWebAuth:Port: 3 MAC: 3448ed-47bfee RADIUS CHAP
       authentication started, session: 271.
    0002:23:29:42.83 MAC  mWebAuth:Port: 3 MAC: 3448ed-47bfee new client detected on
       vid: 1.
    0002:23:29:42.83 AUOR  mWebAuth:Auth Order: Port 3: Client status updated for
       client: 3448ed-47bfee, auth-method: 1 , auth-state: 1 .
    0002:23:29:42.83 AUOR  mWebAuth:Auth Order: Port 3:Added auth order client:
       3448ed-47bfee.
    0002:23:29:42.83 AUOR  mWebAuth:Port: 3 MAC: 3448ed-47bfee Auth Order : 802.1x
       is not configured for port.
    0002:23:29:42.59 MAC  mWebAuth:Port: 3 now being monitored for mac-based
       authentication.
    0002:23:29:39.59 MAC  mWebAuth:Port: 3 now off-line.
    0002:23:29:38.30 MAC  mWebAuth:Port: 3 now being monitored for mac-based
       authentication.
    # show port-access clients  3 D
     Port Access Client Status Detail
      Client Base Details :
       Port            : 3                     Authentication Type : mac-based
       Client Status   : rejected no vlan      Session Time        : 4 seconds
       Client Name     : 3448ed47bfee          Session Timeout     : 0 seconds
       MAC Address     : 3448ed-47bfee
       IP              : n/a
      Access Policy Details :
       COS Map         : Not Defined           In Limit Kbps       : Not Set
       Untagged VLAN   : Not Set               Out Limit Kbps      : Not Set
       Tagged VLANs    : No Tagged VLANs
       Port Mode       : 1000FDx
       RADIUS ACL List : No Radius ACL List
       Auth Order      : Not Set
       Auth Priority   : Not Set
       LMA Fallback    : Disabled
    The attributes are being sent back + captive portal and now there's no ACL and no VLAN?
    Where am I going wrong here?
  • 2.  RE: Trouble with wired captive portal on central with 2930m
    Posted 13 days ago
    Hi, can you share how are the ACLs and the role are configured?
  • 3.  RE: Trouble with wired captive portal on central with 2930m
    Posted 13 days ago
    No role. I'm configuring it via central UI group so I haven't seen a way to configure a role there.
    I'm sending back nas-filter-rules allowing access to DNS, DHCP and clearpass (where the portal lives). So it's a RADIUS ACL. Is there a different way I should be doing this?
