Comware
Trunk between Comware and Aruba OS-CX
This thread has been viewed 16 times
  • 1.  Trunk between Comware and Aruba OS-CX
    Posted Jun 07, 2023 02:08 PM
    I want to configure a trunk between a 5820/5800 and an Aruba 6000 switch.
    Unfortunately this is my first Aruba OS-CX switch and I get my trunk configured between Comware and Aruba CX.
    Just for information the 5800 is in a remote office where the Aruba 6000 should go. Here we have a 5820 where I wanted to test the Aruba 6000 first. Before I do not get the connection on site
    Normally I configure the trunk under Comware like this
    interface Ten-GigabitEthernet1/0/24
     port link-mode bridge
     port link-type trunk
     undo port trunk permit vlan 1
     port trunk permit vlan 200 240
     port trunk pvid vlan 200
     port link-aggregation group xx
     dhcp-snooping trust
    interface Bridge-Aggregationx x
     link-aggregation mode dynamic
     dhcp-snooping trust
    on the Aruba 6000 page I configured it like this
    interface lag 1
        description xxx
        no shutdown
        vlan trunk native 200
        vlan trunk allowed 70,111,180,200,240
        lacp mode active
        dhcpv4-snooping trust
    interface 1/1/27
        no shutdown
        lag 1
    interface 1/1/28
        no shutdown
        lag 1
    where is my mistake? except that the vlans do not fit
    I have already configured the following on the 5800.
    interface Bridge-Aggregation x
     description xxx
     port trunk permit vlan 70 180 200 240
    interface GigabitEthernet1/0/13
     port trunk permit vlan 70 111 180 200 240
  • 2.  RE: Trunk between Comware and Aruba OS-CX
    MVP GURU
    Posted Jun 07, 2023 03:50 PM
    It's not clear, are you trying to interlink a 5800 with ONE interface (member of a LAG with LACP) and an Aruba CX 6000 with TWO interfaces (members of LAG with LACP)? I expected a 2:2 LAGs (2 ports LAG with LACP to 2 ports LAG with LACP). Where is the second member port of Bridge-Aggregationx x logical interface if only one Ten-GigabitEthernet 1/0/24 is listed (or, at the end of your post, a GigabitEthernet 1/0/13 is listed). Then, starting with physical interfaces in their default states, the VLAN membership should be configured (imposed) only on the BAG (Bridge Aggregation Group) logical interface (that configuration propagates back to BAG member interfaces so you should not have mismatch between BAG and its member interfaces). Mismatch - at VLAN tagging level - between peer interfaces (5800 side and 6000 side) it's then another point BUT once you have the Native VLAN and the allowed VLAN list that are matching you should be good.
  • 3.  RE: Trunk between Comware and Aruba OS-CX
    Posted Jun 08, 2023 01:26 AM
    No, of course there are always 2 interfaces.
    On the 5820 it is 1/0/24 and 2/0/24.
    On the 5800 it is 1/0/13 and 1/0/14
    On the 6000 it is 1/1/27 and 1/1/28
    I also know that a trunk/lag/bag consists of at least two ports and the other ports are configured the same way.
    On the Aruba 6000 I get the error message
    sh lacp interfaces
    State abbreviations :
    A - Active        P - Passive      F - Aggregable I - Individual
    S - Short-timeout L - Long-timeout N - InSync     O - OutofSync
    C - Collecting    D - Distributing
    X - State m/c expired              E - Default neighbor state
    Actor details of all interfaces:
    Intf       Aggr       Port  Port  State   System-ID         System Aggr Forwarding
               Name       Id    Pri                             Pri    Key  State
    1/1/27     lag1       28    1     ALFOE   ec:50:aa:81:b6:80 65534  1    lacp-block
    1/1/28     lag1       29    1     ALFOE   ec:50:aa:81:b6:80 65534  1    lacp-block
    Partner details of all interfaces:
               Name       Id    Pri                             Pri    Key
    1/1/27     lag1       0     0     PLFOEX  00:00:00:00:00:00 0      0
    1/1/28     lag1       0     0     PLFOEX  00:00:00:00:00:00 0      0
  • 4.  RE: Trunk between Comware and Aruba OS-CX
    Posted Jun 08, 2023 03:24 AM
    Hi Sven,
    Can you remove VLAN 200 from the trunk(on both) as it's already set for the PVID to go as untagged?
    interface lag 1
        description xxx
        no shutdown
        vlan trunk allowed 70,111,180,240
        lacp mode active
     port trunk permit vlan 240
     dhcp-snooping trust
    Brian
