this is my configuration :
Aruba 2930M :
Running configuration:
stacking
member 1 type "JL319A" mac-address 3821c7-4a3xxx
member 1 priority 255
member 2 type "JL319A" mac-address 3821c7-4acxxx
exit
hostname "Aruba-Stack"
trunk 1/24,2/24 trk1 trunk
snmp-server community "public" unrestricted
oobm
ip address 192.168.xx.xxx 255.255.255.192
ip default-gateway 192.168.xx.xxx
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1/1-1/8,1/10,1/12-1/15,1/23,2/1-2/6,2/8,2/10-2/13,2/20,Trk1
untagged 1/9,1/11,1/16-1/22,2/7,2/9,2/14-2/19,2/21-2/23
no ip address
exit
vlan 10
name "vlan_A"
untagged 1/7,2/6
tagged 1/8,1/10,1/12,1/22-1/23,2/8,2/10,2/12,2/22,Trk1
no ip address
exit
vlan 20
name "vlan_B"
untagged 1/1-1/6,1/8,1/13-1/15,2/1-2/5,2/13
tagged 1/7,1/9-1/11,1/22-1/23,2/7,2/9,2/11,2/20,2/22,Trk1
no ip address
Aruba-Stack(config)# show trunks
Load Balancing Method: L3-based (default)
Port | Name Type | Group Type
1/24 | 100/1000T | Trk1 Trunk
2/24 | 100/1000T | Trk1 Trunk
Cisco 4948:
vlan 10
name vlan_A
vlan 20
name vlan_B
interface Port-channel2
switchport
switchport trunk allowed vlan 10,20
switchport mode dot1q-tunnel
switchport nonegotiate
interface GigabitEthernet1/7
switchport trunk encapsulation dot1q
switchport mode trunk
channel-protocol lacp
interface GigabitEthernet1/8
cisco#sh etherchannel 2 detail
Group state = L2
Ports: 0 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: -
Minimum Links: 0
Port-channels in the group:
Port-channel: Po2
Age of the Port-channel = 5d:16h:57m:01s
Logical slot/port = 11/2 Number of ports = 0
GC = 0x00000000
Port state = Port-channel Ag-Not-Inuse
Protocol = -
Port security = Disabled
Time since last port bundled: 5d:13h:32m:07s Gi1/7
Time since last port Un-bundled: 5d:13h:22m:50s Gi1/8
Do i need to configure STP to prevent mesh packet traffic or loop?or it is enough to use LACP?my configuration use etherchannel "trunk".
and do LACP prevent looping/broadcast storm?
and just to make clear about configuration my server are ESX with 4 interfaces (2 interfaces for vmkernel traffic and 2 interfaces for data traffic). The interfaces just in tagged vlan mode with load balance "route based on originating virtual port", no LAG configured on aruba switch side.
kindly need your advice. Thank You
Best Regards
