Trunked port vs each vlan on its own port
  • 1.  Trunked port vs each vlan on its own port
    Posted Nov 28, 2011 05:31 PM
    Hello everyone,
    We have 4 vlans on our network,  and a 3400 controller,  so 4 ports total.     Is it better as far as performance is concerned to trunk all 4 vlans to one port,   or to put each vlan on its own port?     I assume each to its own port would help remove a bottleneck,  but i'm wrong quite often!
    Brandon
    #3400
  • 2.  RE: Trunked port vs each vlan on its own port
    Posted Nov 28, 2011 09:39 PM
    Measure the utilization on that port and you would be suprised at the answer.
  • 3.  RE: Trunked port vs each vlan on its own port
    Posted Nov 29, 2011 03:11 AM
    I'd recommend both assuming your switches are of a good new and solid type. Assuming your switches support it, create a port-channel, aggregate all four ports together and trunk/vlan-tag the connection as a whole. Best of both plus resilient to port failure!
  • 4.  RE: Trunked port vs each vlan on its own port
    Posted Nov 29, 2011 08:38 AM
    Switch should support just about anything,  its a HP procurve 5406_zl.    Does the aruba 3400 controller support link aggregation?   Didn't see any options for it.
  • 5.  RE: Trunked port vs each vlan on its own port
    Posted Nov 29, 2011 08:42 AM
    Yes.  Please search the user guide for link aggregation.
  • 6.  RE: Trunked port vs each vlan on its own port
    Posted Nov 29, 2011 10:18 PM
    See the Appendix in campus VRD availabel at www.arubanteworks.com/vrd
