Hello Community!
I have an issue to connect trunking interfaces between Fortigate 200D and 2 Procurve 3800 switches.
Here is how I have it set up:
I have couple of vlans say: vlan11, vlan12, and vlan50. Identical port assignment on both switches. Ports 25 are connected with SFP+ cable. Potr 25 is carrying tagged traffic for all vlans. This is simply to connect two switches
Now I have ports 1 and 2 also setup as trunks and they only carrying tagged traffic for vlan11, vlan12 on both switches.
Port1 on switch1 is connected to NIC1 on Hyper-v server. I created virtual Hyper-v switch from NIC1. Each VM now can pass tagged traffic depending on their corresponding vlan.
Port2 on switch2 is connected to Int1 on Fortigate device which is also carrying tagged traffic for vlan11 and vlan12.
This way everything works.
The second I move both Hyper-V wire and Fortigate wire to one switch port 1&2 it stops working. It doesn’t matter which switch, switch1 or switch2.
For it to work hyper-v and fortigate trunks must be connected to separate switches.
I need to have it working in both scenarios since I'm planning to do NIC teaming on Hyper-v. One connection to Hyper-v server is not an option.
I disabled STA, no help. Only these two lines related to STA exist and I cant get then removed
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
Trk1 are ports 1&2
Trk2 are ports 25&26
I banging my head for the second day and can't get this to work.
I will highly appreciate any advice.
Thank you
P.S. This thread has been moved from Comware-Based to ProCurve / ProVision-Based. -HP Forum Moderator
#firewall
