I received the afore mentioned switch with 5.20-r1211 installed. That boots fine.
I tried to upgrade to 5.20-r1810p13 and I get the output below. At the "invalid version" the switch reboots. I had to do a CTRL-B in order to boot to the backup version to get back up and running.
The switch is H3C branded (S5820X-28S) but has an HP sticker on the bottom with the JC102A HP part number on it. I assume that getting the 1810p13 firmware off the HP site is appropriate in this situation. The h3c site would not let me download the firmware from there.
Any thoughts on what I'm doing wrong? I read through the release notes and didn't see anything about pre-requisites that I needed to install first.
Thanks for any and all assistance.
Press Ctrl-B to enter Extended Boot menu...0
Starting to get the main application file--flash:/5820x-cmw520-r1810p13.bin!....
The main application file is self-decompressing.................................
Done!
The application file is self-decompressing......................................
...................................................Done!
System is starting...
Invalid version
Starting......
#firmwareupdate
