SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Tunnel between VPNC & branch gateway
  • 1.  Tunnel between VPNC & branch gateway
    Posted 3 days ago
    For my test-lab I want to create a tunnel between the Virtual Gateway (VPNC) in a datacenter and a physical gateway in my home setup.
    I got experience in the Silverpeak/edgeconnect setup, so SD-wan at his own isn't new for me.
    I want to have more expierence in the SD-branch portofolio.
    But the VPNC concentrator is behind a router/modem of the ISP so NAT is being performed.
    I'm aware that's not ideal, but want to know if that is the issue.
    The Branch gateway at home has a public IP via PPPoE authentication, so no natting.
    What I see in the aruba central is that he discovered the public IP of both nodes.
    And want to setup the tunnel, but never comes up.
    I see both the correct uplinks on both devices in central.
    I enabled overlay mode Orchestrated & peering enabled but the correct hub selected.
    What I'm doing wrong and how can I troubleshoot this?
  • 2.  RE: Tunnel between VPNC & branch gateway
    Posted yesterday
    Just a reminder, that it's a complete SD-branch setup.
    With virtual gateway licenses  & all other licenses are ok.
  • 3.  RE: Tunnel between VPNC & branch gateway
    Posted 6 hours ago
    Make sure you are allowing UDP4500 through the ISP modem/router.  This should work just fine.
