Tunnel establishment between Access point And Aruba controller
This thread has been viewed 19 times
  • 1.  Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 02:48 AM
    Am new to WLAN and also new to ARUBA products.
    Topology :
    ArubaAccessPoint(CAP) ----> DistributionSwitch -----> ArubaController
                                                            DHCPServer
    Initially any tunnel establishment will happen b/w AP and AC immediately After AP associated with AC
    Below is scenario :
    1. AP is in Campus access mode.
    2. AP got ip address from DHCP Server
    3. AP upgrade with image and basic configuration from Controller (AP is in "default" group)
    4. ?
        (here tunnel will be established b/w AP and AC ? )
    Appreciate your prompt response
  • 2.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 03:52 AM
    While going through the Aruba documents found , GRE tunnel will be created b/w AP and AC.
  • 3.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 03:55 AM
    Have one more doubt regarding this , is there in exceptional scenario where tunnel won't esablish b/w AP and AC.
  • 4.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 06:54 AM
    No.  It always happens that way, by default.
  • 5.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 08:31 AM
    Thanks Joseph.
    Is this true for RAP (Remote Access Point) also in bridge mode ? as in one of the document they have mentioned
    """The bridge-mode SSIDs do not have a GRE tunnel back to the controller"""
  • 6.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 08:32 AM
    RAPs have an ipsec tunnel for management.
  • 7.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 08:44 AM
    Thanks Joseph.
    in both cases (GRE and IPSEC tunnel) , is PAPI used for detecting connection's health ?
  • 8.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 09:08 AM
    that means "ipsec tunnel will be established in RAP irrespective of forwarding-modes (Bridge,tunnel,split-tunnel .....) ?.
    Am beginer , are there any documents available to get clear idea on different RAP forwarding modes (Bridge,tunnel,split-tunnel .....).
  • 9.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jul 15, 2014 01:00 PM
    Hi Sorry for catching up late with this conversation, for CAP to Controller by using GRE tunnelling, does it imply there will be no data encryption for the traffic pass through? i 'm a beignner for this, but from end devices to APs after the successful authenticaions the traffic will be encrypted by WPA+AES?
  • 10.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jul 15, 2014 01:05 PM
  • 11.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jul 15, 2014 03:06 PM
    Whatever encryption is used on the wifi, is tunneled back encrypted in the GRE tunnel.
  • 12.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 08:53 AM
    In a campus ap, papi is used for control and ap state monitoring. Gre is used for tunneling user traffic.
    In a remote ap that is done over ipsec.
  • 13.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 23, 2013 09:12 AM
    1. Yes. Rap will have an ipsec tunnel regardless of forwarding mode.
    The user guide at support.arubanetworks.com and the Aruba Validated Reference guides are a good starting point.
  • 14.  RE: Tunnel establishment between Access point And Aruba controller
    Posted Jan 24, 2013 05:17 AM
    Thanks Joseph
