Tunnel from AP eth1 to GRE?
  • 1.  Tunnel from AP eth1 to GRE?
    Posted Jan 23, 2019 09:50 PM
    Is it possible to assign port ETH1 on IAP-345 to use a VPN tunnel, for use by Wired guests?
    (I already have the VPN tunnel created and assigned to one of the Guest  WLANs by L2-Centralised DHCP)
  • 2.  RE: Tunnel from AP eth1 to GRE?
    Posted Jan 24, 2019 06:34 PM
    I've just tested this in my lab using AP303H and it works using the same method as WLAN: just select the Centrailise-L2 DHCP scope in the wired profile and the traffic will go use the GRE tunnel.
    But unfortunately my AP345s are being controlled by Airwave and there seems to be a bug in Airwave 8.2.7 because it doesn't present any dropdown menu for selecting DHCP policies when editing the Wired network profile IGC mode. See attached screenshot.
