last person joined: 11 hours ago
Tunnel GRE between Instant
  • 1.  Tunnel GRE between Instant
    Posted Mar 19, 2015 06:43 AM
    Hi guys,
    I have the following architecture : 4 IAP are on the same VLAN X.Only the Virtual controller can be configured to have an additionnal VLAN Y where I want to put my wireless users.
    Is it possible for the 3 IAP to build a GRE tunnel for the users traffic in the VLAN Y ?
    Please find attached the architecture .
    Thanks for you answers
  • 2.  RE: Tunnel GRE between Instant
    Posted Mar 19, 2015 11:25 PM
    No. The IAPs can build an IPSec tunnel back to mobility controllers but that's it. The tunneled architecture you're referring to is unique to the mobility controller managed APs.
  • 3.  RE: Tunnel GRE between Instant
    Posted Mar 20, 2015 04:39 AM
    I suspected that this architecture was not possible. Thanks for confirming that.
    Have a  nice day ;)
