last person joined: 3 hours ago
Tunnel GRE hub and spoke
  • 1.  Tunnel GRE hub and spoke
    Posted Jun 14, 2016 08:52 PM
    It is possible to build a tunnel gre in hub and spoke?
    For example
    We would like to have a vlan example vlan 999 to pass between all controllers though a hub
    Let say i got 3 controllers
    I got the vlan 999 that will pass betweent controllers
    Copntroler 1 = 192.168.99.1 Spoke1
    Controler 2 = 192.168.99.2  HUB
    Controller 3 = 192.168.99.3  SPoke2
    Now i build my GRE Tunnel from Hub 1 to spoke 1( The tunnel works fine i can pass traffic between them
    Now i build my GRE tunnel  from hub to spoke 2 ( ( The tunnel works fine i can pass traffic between them)
    Now here is the problem
    If i try to ping from spoke 1 to spoke 2 and the packet has to pass trhough the hub i dont reach...
    Do i need to add anything to make this work? or its impossible?
    The config is something like this :
    HUB to spoke 1
    interface tunnel 60
            tunnel source 10.10.10.5
            tunnel mode gre 0
            tunnel destination 10.10.20.5
    tunnel vlan 999
    trusted
    no inter-tunnel-flooding
    HUB To SPOKE 2
    interface tunnel 61
            tunnel mode gre 0
            tunnel destination 10.10.30.5
    tunnel vlan 5
    trusted
    Should i just enable the inter tunnel flooding?  i saw it in a config  looking for a example of configs but it donest not say too much of what is it on the manual anyways
    Cheers
    Carlos
  • 2.  RE: Tunnel GRE hub and spoke
    Posted Jun 15, 2016 06:30 PM
    It was the non inter tunnel flooding
    I just needed to enable it.
    Cheers
    Carlos
