Tunnel Node
  • 1.  Tunnel Node
    Posted Dec 04, 2017 02:59 AM
    Dear All,
    I have controller running on AOS 6.5.4.3, type 7030,
    switch 2930F with stacking vsf with firmware 16.03,
    and clearpass as radius 802.1x wired,
    i have already configure 802.1x and successfully login with username at my active directory,
    but when I assign that port with tunnel node, it pop up notif, cannot enable tunnel node when port authenticator enable,
    i read in ase.arubanetworks.com tunnel node can enable with authentication 802.1x , where I am wrong the configuration ?
    please advice....
  • 2.  RE: Tunnel Node
    Posted Dec 04, 2017 08:26 AM
    You cannot have the "aaa port-access authenticator" command configured for the port.
  • 3.  RE: Tunnel Node
    Posted Dec 04, 2017 11:18 AM
    Dear Cappalli,
    So , what should i do sir ?
    if I remove the aaa port auth, the device wont have authentication 802.1x ?
    kindly need your advice
  • 4.  RE: Tunnel Node
    Posted Dec 04, 2017 11:31 AM
    Please look at the ClearPass Solution Guide for Wired Policy Enforcement.
