Tunnel Nodes on MAS
  • 1.  Tunnel Nodes on MAS
    Posted Jul 09, 2013 08:38 PM
    Hello All,
    I know what Tunnel Node does, however, can some please provide some insight into how it works.
    So if I have all my Security Policies and Authentication profiles on the Mobility Controller, how can I tell which of the Policies is applied to the Tunnel Node Port on the MAS.
    For example, if I have 802.1X and Captive Portal Authentication built on the Mobility Controller. Which of these Authentications will be applied to the Tunnel Node Port?
  • 2.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 08:54 PM
    Both of those mechanisms can be appled to a tunneled node port. The AAA function is based off of what you apply in the aaa authentication wired profile on the controller.
    If you run a show aaa authentication wired command on the controller, it will show you the aaa profile that is assigned.
    (WLC-3600) #show aaa authentication wired
    Wired Authentication Profile
    Parameter    Value
    AAA Profile  default
  • 3.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 08:58 PM
    @cappalli wrote:
    Parameter    Value
    AAA Profile  default
    Thanks Tim. However, it seems that I have to apply the aaa authentication wired profile to either 802.1X or Captive Portal. Is that correct?
    If so, that means you can only do one or the other and not both on a per Port basis. Correct?
  • 4.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 09:23 PM
    Are you trying to do 802.1X with captive portal fall back?
    Sent from my BlackBerry Z10
  • 5.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 09:24 PM
    Yes I am.
  • 6.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 09:28 PM
    You should be able to put the captive portal logon role as the initial role in the AAA profile so if 1X fails, they will be dumped into the initial role.
  • 7.  RE: Tunnel Nodes on MAS
    Posted Jul 09, 2013 09:32 PM
    Good idea.
    Will give that a shot.
    Thx.
