Tunnel-Private-Group-Id
  • 1.  Tunnel-Private-Group-Id
    Posted Feb 14, 2014 11:17 AM
    Hi, i need help me. I have configure portal cautive, i need assigment other vlans. My configured is correct?
    I have aruba os6.3 + ClearPass
    Attachments image
  • 2.  RE: Tunnel-Private-Group-Id
    MVP
    Posted Feb 14, 2014 12:27 PM
    If you're using Aruba controllers, why not just return the Aruba VSA?
  • 3.  RE: Tunnel-Private-Group-Id
    Posted Feb 14, 2014 12:35 PM
    If you are trying to switch the users vlan after they have authenticated via a captive portal, then that is fraught with difficulties.  It is possible, though I would not recommend it.
    The problem is that the device already has an ip, and then it's vlan is switched.  It may take devices some time before they realise and then do another dhcp request,  with some devices never realising and then never having any network.
    There are some other post in here which have some neat workarounds, but they are sort of fudges.
    I would recommend only changing a users vlan via radius attribute with a dot1x ssid.
  • 4.  RE: Tunnel-Private-Group-Id
    Posted Feb 14, 2014 03:06 PM
    Hi, is possible install ClearPass Policy Manager 6.3 in HYPER-V?
    Thanks!!!
  • 5.  RE: Tunnel-Private-Group-Id
    Posted Feb 14, 2014 03:07 PM
    As of today it is an unsupported VM.
