tunnel vap and bridge vap same ap group question
This thread has been viewed 16 times
  • 1.  tunnel vap and bridge vap same ap group question
    Posted 8 days ago
    hi dear
        If there are both tunnel ssid and bridge ssid under one AP group, will there be any problems in use?
        Because this kind of situation has not been encountered in the project, we generally separate the two modes into different ap groups.
    leo ma
  • 2.  RE: tunnel vap and bridge vap same ap group question
    Posted 7 days ago
    Hi, no problem at all having 2 ssids with diferent types in the same group. It's common.
    Edit: Assuming the SSIDs are different, just the type is different
    Regards
  • 3.  RE: tunnel vap and bridge vap same ap group question
    Posted 7 days ago
    In my experience, configuring the same SSID in the same Ap-group registers an error.  If this is not prevented and you are broadcasting the same SSID twice in the same Ap-group, how would you know or control which one you are connecting to?
  • 4.  RE: tunnel vap and bridge vap same ap group question
    Posted 7 days ago
    hi ,is not same ssid,only same ap-group,The bridge mode encryption and decryption are all in the AP. I don't know if it will be a problem if it is mixed with the tunnel.
    is this
    leo ma
  • 5.  RE: tunnel vap and bridge vap same ap group question
    Posted 7 days ago
    thank you
    leo ma
  • 6.  RE: tunnel vap and bridge vap same ap group question
    Posted 6 days ago
    I apologize for not understanding.  Yes, you can do that.
