Cloud Managed Networks
Tunneled SSID AAA-Profile
  • 1.  Tunneled SSID AAA-Profile
    Posted 25 days ago
    I'm currently running a WLAN gateway cluster and some campus access-points on AOS code 10.4. On the access-points, I've got some tunneled SSID configured. It seems that Aruba Central does automatically create and assign AAA-Profiles for every tunneled SSID on the gateway side. Would there be any option to manually create a new AAA-Profile and assign it to a bunch of tunneled SSID's?
  • 2.  RE: Tunneled SSID AAA-Profile
    Posted 25 days ago
    if you go through the adding a new WLAN wizard then the aaa profiles gets automatically created for the gateways. But other wise you can go to the gateways group and modify it as required.
  • 3.  RE: Tunneled SSID AAA-Profile
    Posted 24 days ago
    Hi ariyap
    Thanks for your input. This is already clear to me. My question is not really about modify the AAA-profile itself, but the possibility to use the same AAA-profile for different SSID's. So the default behaviour when create a new tunneled SSID would look like this:
    SSID "A" -> AAA-Profile "A"
    SSID "B" -> AAA-Profile "B"
    SSID "C" -> AAA-Profile "C"
    What I'm trying to do is the following:
    SSID "A" -> AAA-Profile "X"
    SSID "B" -> AAA-Profile "X"
    SSID "C" -> AAA-Profile "X"
    I'm currently looking for a way to use the same AAA-Profile for different tunneled SSID. Looking at the WebUI I could not see any option to do this.
  • 4.  RE: Tunneled SSID AAA-Profile
    Posted 22 days ago
    yes that seems to be. I guess we need to wait for the new Central which seems to have lots of enhancements.
