Tunneled traffic is intermittant
  • 1.  Tunneled traffic is intermittant
    Posted Mar 02, 2020 04:59 PM
    I'm trying to set up a guest wireless solution. First I was testing the tunneling settings on my WLAN to my controller. When my test host connected, it got an IP from the DHCP server I have on the same subnet as the controller. AFter that, the connectivity gets intermittant. I thought it might be roles but even with authenticated as a default role, it still fails. I also thought it might be an address conflict but even with a reservation, I get the same behavior. I'll be able to ping the host for about 30 seconds and then it drops off the network. Any suggestions on where I should check first? I just want to rule out the aruba portion of the system before moving forward.
  • 2.  RE: Tunneled traffic is intermittant
    MVP
    Posted Apr 10, 2020 10:39 AM
    1. Does the device receive the IP address offer by DHCP and does it Accept the IP and send a DHCP acknowledgement?
    2. Does the device make it into the user-table of the controller?
    3. After the pings stop, does the device still show in the user-table?
    4. Do you have any other devices on guest that continue to work or is this the only one?
    5. Have you tried connecting the device to a different AP?
    6. In the AP's LMS controller, try "show ap client trail-info <mac>" and view the deauth events. What do they show?
  • 3.  RE: Tunneled traffic is intermittant
    Posted Jul 29, 2020 11:47 AM
    Sorry for the late reply. Covid got us all and I wasn't on a site with our guest network deployed.
    1. Yes
    2. yes
    3. yes
    4. All devices on the guest network seem to do this. Tested with two laptops and a phone
    5. Not yet as we're only testing at one site so far. I can try on another site if needed.
    6. I get the following output for this:
    Deauth Reason
    Reason                           Timestamp
    Unspecified Failure              Jul 29 11:18:40
    Sapcp Ageout (internal ageout)   Jul 29 11:06:56
    Num Deauths:2
