Tunnelled node into 7008 controller
  • 1.  Tunnelled node into 7008 controller
    Posted Oct 09, 2020 02:38 PM
    Hi all,
    Just wanted to check my logic as it’s the first time I’ve played with tunnelled node.
    I will use a 5400 switch and 7008 controller.
    On the 5400 switch; I will:
    - Enabled tunnelled node at global level and point to management IP of the controller
    - At interface level, set to tunnelled node port and assign a VLAN (2000)
    On the 7008 controller; I will:
    - Make VLAN 2000 And assign whatever security I need around this VLAN
    Questions:
    1. Do I need to tick an option on the controller to make this work? Feels like I should enable this feature on the controller like I’m doing on the switch?
    2. Will telling the interface on the switch transpose into the controller? So users will just present on the same VLAN as the switch when they land in the controller?
    3. I have a firewall between the switch and controller. Does tunnelled node use the management IP of the switch as it’s source? Is it just GRE traffic?
    4. I feel like I’m missing some fundamentals above or is it this easy?
    I’m manually configuring certain ports for tunnelled node; trying to avoid getting Clearpass involved etc
    many thanks
  • 2.  RE: Tunnelled node into 7008 controller
    Posted Oct 13, 2020 03:37 PM
    Can anyone comment on this one?
  • 3.  RE: Tunnelled node into 7008 controller
  • 4.  RE: Tunnelled node into 7008 controller
    MVP GURU
    Posted Oct 13, 2020 03:41 PM
    And here is a great guide for AOSv8. Even has the same controller as you
    https://www.youtube.com/watch?v=gVLVuiiGmRE
  • 5.  RE: Tunnelled node into 7008 controller
    Posted Oct 13, 2020 03:54 PM
    Great video talk through - thanks very much
  • 6.  RE: Tunnelled node into 7008 controller
    Posted Oct 14, 2020 08:58 AM
    The only unknown part for me now is having a firewall in between this switch and controller.
    Do you know what source IP the tunnelled node will pick to route this traffic? The only layer 3 address on this switch is the OOBM interface at present.
    thanks
  • 7.  RE: Tunnelled node into 7008 controller
    Posted Oct 14, 2020 08:59 AM
  • 8.  RE: Tunnelled node into 7008 controller
    MVP GURU
    Posted Oct 14, 2020 09:13 AM
    It will be sourced from the switch IP as a tunnel is created between the switch and the controller. You can see what IP on the switch is being used in the "show user-table" output on the controller under Essid/Bssid/Phy. Should be the first part of the address.
  • 9.  RE: Tunnelled node into 7008 controller
    Posted Oct 14, 2020 10:01 AM
    Just to clarify - switch IP; is this the OOBM address? So the management address? This is the only layer 3 address on the switch basically ... all other traffic goes through a layer 2 trunk to a core switch
  • 10.  RE: Tunnelled node into 7008 controller
    MVP GURU
    Posted Oct 14, 2020 10:06 AM
    Someone would have to chime in here as far as the source IP of the GRE tunnel, and if and how you can change that. That particular video had just one L3 address on it. If I had to guess, it would be the Highest IP with reachability. But I would be guessing at the moment.
  • 11.  RE: Tunnelled node into 7008 controller
    Posted Oct 15, 2020 10:51 AM
    Ok so I’ve tried to get this up and running but it shows the error “controller unreachable” ... I’m looking on the firewall but can’t see any traffic trying to hit the controller.
    does anyone know how it will source its traffic by default? Anyway to force this over the OOBM interface?
  • 12.  RE: Tunnelled node into 7008 controller
    Posted Oct 16, 2020 04:04 PM
    Also make sure your 7008 controller IP is the first one traffic hits coming from 5400. This issue was supposed to be fixed in 8.5.0.10 but haven't yet verified. So for example using loopback IP address will not work
  • 13.  RE: Tunnelled node into 7008 controller
    Posted Oct 16, 2020 04:15 PM
    Ok thanks
    In terms of traffic flow; there is
    5400 switch (access layer)
    8320 switch (core switch)
    firewall
    7008 controller
    Guessing this is a non starter going off your comments? Do I need to put layer 2 through to the controller from the switch?
  • 14.  RE: Tunnelled node into 7008 controller
    Posted Oct 16, 2020 04:37 PM
    It works over a routed network no problems there, or over a firewall. But for example if you have GE 0/0/0 as the interface towards the switch network you need to configure the IP ont GE 0/0/0 as controller IP and the one switch connects to form a tunnel.
    Just downloaded 8.5.0.10 so I'll have to check if they have fixed this
  • 15.  RE: Tunnelled node into 7008 controller
    Posted Oct 16, 2020 04:48 PM
    That makes sense - yes I have that setup
    My issue is the switch says “controller unreachable” ... the switch has layer 2 only as all the VLANs trunk up to a 8320 core switch. The core switch then connects to a firewall which protects the controller.
    im wondering if the switch is layer 2 only, it has no way of routing the tunnelled node traffic. It does have a OOBM interface configured with an IP for its management traffic - guessing tunnelled node cannot traverse the management interface?
    Should I add a layer 3 address to the switch? I can’t see a way to force tunnelled node over a specific source address?
  • 16.  RE: Tunnelled node into 7008 controller
    Posted Oct 16, 2020 04:49 PM
    Have you checked the debug logs, with debug destination session + debug usertn? If I would have to guess I'd say OOBM would not work for tunneled node
