turning AP off when not in use
  • 1.  turning AP off when not in use
    Posted Apr 11, 2012 06:13 AM
    Is there any way by which we can turn off the APs when no wifi usage is observed?
    or time based on/off ?
    or may be APs will consume less power when no users are connected ?
    client requirement :smileyfrustrated:
  • 2.  RE: turning AP off when not in use
    Posted Apr 11, 2012 10:44 AM
    There's nothing in Aruba that I know of that will power down a RAP at specific times, but you can disallow clients from connecting to its VAPs during specific times.  I'm thinking that's not what you're looking for, but that's as far as Aruba can go.
    The only other thing I can think of is if the AP is connected to a switch that is providiing PoE, you could write a scipt that logs into the switch, does a shutdown on the AP's port, then does a no shut when you want it back up.
  • 3.  RE: turning AP off when not in use
    MVP EXPERT
    Posted May 28, 2012 06:53 AM
    The S3500 switch supports siwtching off specific AP's during certain times in order to save power.
    http://www.arubanetworks.com/pdf/technology/TB_S3500.pdf
