Turning off Wi-Fi
  • 1.  Turning off Wi-Fi
    Posted May 24, 2017 04:18 PM
    I have a customer asking if there are any options using Aruba Instant and the built in VC to turn off his Wi-Fi at night.  If it is not an option would Aruba Central give me that option?
    Brandon
  • 2.  RE: Turning off Wi-Fi
  • 3.  RE: Turning off Wi-Fi
    Posted May 25, 2017 11:13 AM
    Hi Colin,
    Would this turn off the wireless signal coming from the AP's?  This customer has 6 IAP 205's throughout his home and does not want the signal\wireless on at night.  So basicially turning off the AP's with out turning them off.  If that makes sense.
    Brandon
  • 4.  RE: Turning off Wi-Fi
    Posted May 25, 2017 11:17 AM
    It would just not allow connections.  It does not shut off the radio.  You would probably look to a switching platform that has time-based POE for that...
