Tutorial - Clearpass TACACS+ Fortigate Login
This thread has been viewed 35 times
  • 1.  Tutorial - Clearpass TACACS+ Fortigate Login
    MVP EXPERT
    Posted Sep 16, 2020 12:52 PM
    In this post i will describe the configuration needs to use TACACS+ for authentication login on a Fortigate (v6.0.10). Fortigate KB Article for reference here, link.
    Configure your Fortigate for TACACS+ Authentication
    ### ADD TACACS SERVER
    config user tacacs+
        edit "ClearPass"
           	set server "172.16.200.2"	###CLEARPASS IP ADDRESS###
       	set key “SECRETHERE”	        ###CLEARPASS NAD PSK SECRET###
           	set authorization enable
            set authen-type pap	        ###DONT USE CHAP###
        next
    end
    ### ADD TACACS USER GROUP
    config user group
        edit "ClearPass-TACACS"
         	set member "ClearPass"		###CLEARPASS SERVER###
        next
    end
    ### CREATE A ACCESSPROFILE WITH NOACCESS
    config system accprofile
          edit "noaccess"
        next
    end
    ### CREATE A BACKGROUND USER
    config system admin
        edit "tacacs_admin"
            set remote-auth enable
            set accprofile "noaccess"
            set vdom "root"
            set wildcard enable
            set remote-group "ClearPass-TACACS"
            set accprofile-override enable
        next
    end
    Configure Aruba ClearPass TACACS+ Dictionary
    First things first! When configuring TACACS+ for a Fortigate it’s important that the Fortigate TACACS+ Dictionary is loaded into the ClearPass server. Easy import the below .xml script below.
    Note: This point is where i was failing the fist time ;).
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
      <TipsHeader exportTime="Wed Sep 16 15:08:59 CEST 2020" version="6.9"/>
    <TacacsServiceDictionaries>
        <TacacsServiceDictionary dispName="fortigate" name="fortigate">
          <ServiceAttribute dataType="String" dispName="service" name="service"/>
          <ServiceAttribute dataType="String" dispName="memberof" name="memberof"/>
          <ServiceAttribute dataType="String" dispName="admin_prof" name="admin_prof"/>
        </TacacsServiceDictionary>
      </TacacsServiceDictionaries>
    </TipsContents>
    Configure Aruba ClearPass Enforcement profiles
    We create two enforcement profiles one with administrator rights and one with operator rights. The “memberof” value can be a random name. The “admin_prof” value is the must equal a admin profile in your Fortigate box.
    Configure Aruba ClearPass Enforcement policy
    For this test we create a very simple Enforcement Policy that look into the local user repository and check if the user have the role “TACACS Super Admin” or “TACACS Helpdesk” and when the policy rule hits it will enforce the Admin or Readonly profile.
    Since the “Readony” profile has not yet been created within the fortigate configuration, we now do this for reference via the web-gui.
    Configure Aruba ClearPass Service
    Last but not least… We have to configure the ClearPass Service for the incoming TACACS+ Requests.
    • Type: TACACS+ Enforcement
    • Service Rule: Hits when the NAD (Fortigate) IP equals 172.16.200.254
    • Authentication Source: Local User Repository
    • Enforcement Policy: HomeLAB – Fortigate Policy
    Configure Aruba ClearPass Local Users
    Create in the local user database two accounts:
    • testuser with the role [TACACS Super Admin]
    • testuser-ro with the role [TACACS Helpdesk] (read-only)
    TESTING TIME!!!
    Lets test the configuration from the fortigate CLI. Yes! You can still login with your local admin account, because we didn’t remove it in the Fortigate box.
    Aruba ClearPass Access Tracker
    In the Aruba ClearPass Access Tracker we can monitor the login events.
    Some extra slides about the “testuser” request for reference…
  • 2.  RE: Tutorial - Clearpass TACACS+ Fortigate Login
    Posted Jan 31, 2021 03:24 PM
    Great tutorial. Thank you
    Harendra
    ACDX#1129|ACEP|CWSP|CWNA|CCNA
  • 3.  RE: Tutorial - Clearpass TACACS+ Fortigate Login
    Posted Nov 16, 2022 03:07 PM
    This still holds up as of today. (ClearPass 6.11 and FortiOS 7.0.8) Awesome tutorial.
