[Tutorial] How to patch your Clearpass
  • 1.  [Tutorial] How to patch your Clearpass
    Posted Jun 16, 2013 12:29 PM
    Hello everyone i have decided to do a tutorial on how to do this.
    Guess you guys have seem the patches on the support site these ones:
    The interesting thig is that i have not patched the last one so i will go step by step patching that one.
    Okay lets start
    First we will download the file in my case i need to download clearpass 6.1.1 patch which have to be installed after installing the cummulative patch which i already did...
    You can see what patches you already installed by clicking down on the version here:
    After you click it you will see something like this:
    Those are the patches i got installed, and as you see i got the cummulative installed already there
    Okay now.. lets go to the console and then lets go to the admnistration--->Agent & Software updates--->Software updates
    In there click import  update here:
    And upload the file.. in my case ill upload the file i just downloaded which is the patch im missing.
    After you import it you will see its processing and you will need to wait a few seconds or a min depending ont he file size...
    After that you will see that it would be like nothing happened! but now the file is on the clearpass server and you need to run the update via cli....
    Now you can ssh it and log in
    On the Cli you will run this command
    system update –i  <file name>
    Here is the example as im updating it now:
    system update –i CPPM-x86_64-20130611-clearpass-updates-patch.bin
    Now in some updates it will tell you that you need to reboot! you have to read whats the output and it will tell you if you need to reboot or not... in my case i dont need to.   Also there are other cases that you will loose the conectivity to the web access of the administration which it will tell you that that you need to wait for a while...
    After installing like i did you can check that its succesfully installed on the GUI again .
    Now you see the patch that is installed and well its installed 6-16-2013 which is today
    And now we are done.
    Cheers
    Carlos
    [Mod note: edited subject line for readability]
  • 2.  RE: [Tutorial] How to patch your Clearpass
    Posted Jun 19, 2013 09:54 PM
    Great info.
    Thanks Carlos this will help other users.
  • 3.  RE: [Tutorial] How to patch your Clearpass
    Posted Jun 25, 2013 06:29 PM
    Thank you Carlos for your contribution! We will also host this post in the community knowledge base.
  • 4.  RE: [Tutorial] How to patch your Clearpass
    Posted Jun 25, 2013 06:48 PM
    Thank you Alc ill have more tutorial coming :)
    You can also use if you find them useful these other tutorials i wrote before
    How to correctly configure EAP PEAP on windows machines
    http://community.arubanetworks.com/t5/Authentication-and-Access/Correctly-configure-EAP-PEAP-Windows-client/td-p/43398
    How to configure EAP TLS on Radius Server
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Tutorial-EAP-TLS-Configuration-Guide/td-p/78592
    Cheers
    Carlos
  • 5.  RE: [Tutorial] How to patch your Clearpass
    Posted Jun 25, 2013 06:50 PM
    Thanks Carlos!
  • 6.  RE: [Tutorial] How to patch your Clearpass
    Posted Jul 10, 2013 03:25 PM
    Thanks Carlos!!! That did thte trick!
    Mike
  • 7.  RE: [Tutorial] How to patch your Clearpass
    Posted Jul 11, 2013 02:17 AM
    Just a quick update....
    The latest OVF images that were posted just recently should already include the admin patch.
  • 8.  RE: [Tutorial] How to patch your Clearpass
    Posted Feb 11, 2014 07:51 PM
    Hi there
    Quick question - must patches be installed via the CLI or can they be installed via the GUI.
    I have a patch available under the Software Updates Tab with a nice big INSTALL button next to it.
    Just wanting to see if there are any differences to watch out for.
    Cheers
    Wally
  • 9.  RE: [Tutorial] How to patch your Clearpass
    Posted Feb 11, 2014 09:54 PM
    You can install the patches from the GUI as well.
