Network Management
[Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
This thread has been viewed 64 times
  • 1.  [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 06, 2014 11:58 AM
    This tutorial will explain how to physically add a new drive your VMWare server and increase the diskspace on Airwave to utilize this new drive.
    Attached is a document on how to accomplish this task.
    EDIT: As requested (finally had time), here is the article posted.
    1         Purpose of document
    To be able to extend the hard drive space of an Airwave server deployed on a Virtual Machine using VMWare.
    2         How to add a new SATA drive to an VMWare ESXi Server
    • Insert new drive into spare slot on the server, connect all cables required
    • Boot Airwave server
    • Log into your vSphere application.
    • Navigate to the Configuration section as per below
    Highlight the desired datastore where AMP is installed on.
    Right-click and select ‘properties’
    Click on the ‘Increase’ button and it will discover your new drive, highlight it and click on ‘next’
    Select Maximum available space or if desired custom space setting. Click on ‘next’
    Then click on Finish
    Once you’ve clicked on finish, you will now see both disks and your total capacity changed.
    You can click on close.
    You have now added the new sata drive to your existing datastore.
    3         Modification to the Airwave VM
    Next step is to have Airwave recognize this new hard drive.
    First step is to increase the amount of Hard Drive space the VM will be using
    Go into Edit settings of your VM and click on the hard disk
    Make it whatever size you want (depends on the datastore) and click ok,
    Now let’s make AMP recognize the new HD Space.
    There are multiple ways to accomplish this but I found this to be the easiest.
    Download a LIVE CD version of Ubuntu Desktop and save the ISO
    Select Ubuntu as the ISO for the CDROM Drive
    Reboot AMP and press F2 when prompted to go into the boot screen, choose CDROM as the 1st boot device.
    Save and reboot
    Then Ubuntu begins to load
    Choose language of your choice
    Select ‘Try Ubuntu without installing’
    It begins to load:
    Once it loads, go into the GPARTED program.
    You will now see an unallocated section of HD Space
    Right-Click on it and create new partition and leave the file system to be unformatted.
    Click Apply.
    You should see something like this /dev/sda3
    Next step is to add the LVM flag to the new drive.
    Right-click and click on Manage Flags
    Select the ‘lvm’ flag
    Select LVM and click on close.
    At this time, you can shutdown Ubuntu and boot back into AMP (don’t forget to remove the ISO from the CDROM).
    4         Configuring CentOS to recognize the new drive
    Once AMP has booted up, log in via SSH
    Next step is to make sure you see the new drive added
    # Confirm /dev/sda3 exists or if it gets another name using ‘fdisk –l’
    [root@aw-1 mercury]# fdisk -l
    Disk /dev/sda: 85.9 GB, 85899345920 bytes
    255 heads, 63 sectors/track, 10443 cylinders
    Units = cylinders of 16065 * 512 = 8225280 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk identifier: 0x0009f7c3
       Device Boot      Start         End      Blocks   Id  System
    /dev/sda1   *           1          13      102400   83  Linux
    Partition 1 does not end on cylinder boundary.
    /dev/sda2              13        5222    41839616   8e  Linux LVM
    /dev/sda3            5222       10444    41943040   8e  Linux LVM
    Disk /dev/mapper/VolGroup00-LogVol01: 4294 MB, 4294967296 bytes
    255 heads, 63 sectors/track, 522 cylinders
    Disk identifier: 0x00000000
    Disk /dev/mapper/VolGroup00-LogVol00: 81.4 GB, 81436606464 bytes
    255 heads, 63 sectors/track, 9900 cylinders
    # SDA3 is our new drive
    Now we create the physical volume using the command ‘pvcreate /dev/sda3’
    # Create the one physical volume
    [root@aw-1 mercury]# pvcreate /dev/sda3
      Writing physical volume data to disk "/dev/sda3"
      Physical volume "/dev/sda3" successfully created
    We then check the configuration of the volume group using ‘vgdisplay’
    # Check current configuration of the volume group is 1 physical volume
    [root@aw-1 mercury]# vgdisplay
      --- Volume group ---
      VG Name               VolGroup00
      System ID
      Format                lvm2
      Metadata Areas        1
      Metadata Sequence No  3
      VG Access             read/write
      VG Status             resizable
      MAX LV                0
      Cur LV                2
      Open LV               2
      Max PV                0
      Cur PV                1
      Act PV                1   #Actual Physical Volumes = 1
      VG Size               39.88 GiB
      PE Size               32.00 MiB
      Total PE              1276
      Alloc PE / Size       1276 / 39.88 GiB
      Free  PE / Size       0 / 0
      VG UUID               56Leag-jwVA-RJOD-0WOm-fltC-2fcI-RAKqB1
    Add new SDA3 to the LVM Volume group using ‘vgextend VolGroup00 /dev/sda3’
    # 2. Add it to the volume group
    [root@aw-1 mercury]# vgextend VolGroup00 /dev/sda3
      Volume group "VolGroup00" successfully extended
    Validate volume group
    # Validate size of the volume group
      VG Name               VolGroup00
      System ID
      Format                lvm2
      Metadata Areas        2
      Metadata Sequence No  4
      VG Status             resizable
      MAX LV                0
      Cur LV                2
      Open LV               2
      Max PV                0
      Cur PV                2
      Act PV                2
      VG Size               79.84 GiB
      PE Size               32.00 MiB
      Total PE              2555
      Free  PE / Size       1279 / 39.97 GiB
    Act PV is now 2 and VG size is doubled
    Now let’s resize the volume.
    This depends on the ‘FREE PE / Size’. You must use the value contained there.
    In this case 1279 as indicated above.
    Let’s resize the space using the command below
    # Resize the space
    [root@aw-1 mercury]# lvextend --resizefs --extents +1279 /dev/VolGroup00/LogVol00
      Extending logical volume LogVol00 to 75.84 GiB
      Logical volume LogVol00 successfully resized
    resize2fs 1.41.12 (17-May-2010)
    Filesystem at /dev/mapper/VolGroup00-LogVol00 is mounted on /; on-line resizing required
    old desc_blocks = 3, new_desc_blocks = 5
    Performing an on-line resize of /dev/mapper/VolGroup00-LogVol00 to 19881984 (4k) blocks.
    The filesystem on /dev/mapper/VolGroup00-LogVol00 is now 19881984 blocks long.
    And confirm Free PE / Size is now 0
    # Confirm the LVM volume group has been extended with the
    # new harddrive
      VG Name               VolGroup00
      System ID
      Format                lvm2
      Metadata Areas        2
      Metadata Sequence No  5
      VG Status             resizable
      MAX LV                0
      Cur LV                2
      Open LV               2
      Max PV                0
      Cur PV                2
      Act PV                2
      VG Size               79.84 GiB
      PE Size               32.00 MiB
      Total PE              2555
      Alloc PE / Size       2555 / 79.84 GiB
    [root@aw-1 mercury]# df -h
    Filesystem            Size  Used Avail Use% Mounted on
                           75G  4.8G   67G   7% /
    tmpfs                 3.9G     0  3.9G   0% /dev/shm
    /dev/sda1              97M   36M   57M  39% /boot
    You have now successfully resized AMP to use the extra HD space
    Attachment(s)
  • 2.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 06, 2014 02:31 PM
    Nice!! Think you could add the contents of the pdf into the article?
  • 3.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 06, 2014 02:54 PM
    Will do.!
    I had typed it out so to get my post in. I was planning on doing it, should be able to get it done by tomorrow.
  • 4.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 06, 2014 07:19 PM
    Hey Pasquale,
    Moved your entry under "Unified Wired/Wireless" board since it's about AirWave. Your original link will continue to work.
    Cheers,
    Ozer
  • 5.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 07, 2014 08:13 AM
    Thx Oz.
    I thought Airwave should go into cloud as I see some topics about Airwave there.
  • 6.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 15, 2014 04:18 PM
    Guess not a lot of Airwave VM deployments ;)
  • 7.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 18, 2014 08:29 PM
    We run AMP 7.7.7 on a VM and Rehl 6.x  I just recently moved to this.  Prior I was on Rehl 5 and 7.5.5.  What a pain in the but it was to get to 7.7.7.  Took a few months we had a ton of issues getting there that were no fault of Aruba.  How about you, any install issues?
  • 8.  RE: [Tutorial] Increase diskspace on Airwave running on VMware Jan14-Tutorial
    Posted Jan 20, 2014 03:07 PM
    Unfortunately, I haven't install issues but I have had upgrade issues.
    I have never done an Install on Red Hat though, I've heard of some upgrade or install issues when using Red Hat but we tend to stick to the OS that comes with the ISO which is CentOS.
