Network Management
[Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
  • 1.  [Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
    Posted Nov 04, 2013 10:42 PM
    Hello  In this tutorial ill teach you how to install VMware Tools on CentOS
    If you ever installed Airwave you know that in the installation it will tell you that it recommend first installing the VMWareTools
    Anyways
    This is how you do it:
    1-When you installing airwave by first time you will see the ARUBA LOGO all super BIG which it will tell you to type install
    2-After doing all that it will reboot and it will ask you to type ./amp-amp install but if you hit that it will tell you to please install the VMWare tools before continue... so before doing that do this:
    1. In the VMWare click install vmtools in the console like thi
    On the console type all this:
    1. mkdir /mnt/cdrom
    2. mount /dev/cdrom /mnt/cdrom
    3. cp /mnt/cdrom/VMwareTools-*.tar.gz /tmp
    4. umount /mnt/cdrom
    5. tar -zxf /tmp/VMwareTools-*.tar.gz -C /tmp
    6. cd /
    7. cd tmp
    8. cd vmware-tools-distrib
    9. ./vmware-install.pl --default
    After this it will start installing and you will have to wait some minutes while it install
    After that you will need to reboot it, so reboot the server.
    You reboot by typing in the cli  reboot
    After it finished rebooting before keep installing the airwave check that you got the vmtools installed by doing this
    vmware-toolbox-cmd -v
    You will see something like this:
    After you checked that everything is okay then you can proceed and remove the files
    rm -f /tmp/VMwareTools-*.tar.gz
    rm -rf /tmp/vmware-tools-distrib
    Now you can continue installing the airwave
    Anyways hope it help you all
    If you got any issues with this feel free to ask me on this tread.
    Cheers
    Carlos
    [Mod note: edited title]
  • 2.  RE: [Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
    Posted Nov 05, 2013 08:15 PM
    I forgot mentioning.  That if for some reason you do
    Check if you did not misspelled
    And it give you an error that the command doesnt work or something you might have to reinstall the vmware tools... This happened me once(no idea why it happened as it didnt send any errors)
    Anyways to reinstall it go here
    And click reinstall.
    You just need to start from step number 2 after clicking reinstall WMware Tools
    Cheers
    Carlos
  • 3.  RE: [Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
    Posted Nov 29, 2013 02:26 AM
    Thanks Carlos! Do you have any information on the procedure on Clearpass? What about when you need to upgrade VMWare tools?
  • 4.  RE: [Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
    Posted Nov 29, 2013 08:19 AM
    No i dont have those yet but i can do them...
    When i get some time again ill do it and post them for you all.
    So Coming soon
    Cheers
    Carlos
  • 5.  RE: [Tutorial] Installing VMWareTools on CentOS 6.2 for Airwave
    Posted Nov 06, 2013 03:36 PM
    Thanks.
    I run mine in VirtualBox, so the commands are a bit different, still usefull though.
