[Tutorial] Offload RAP WhitelistDB to Clearpass
  • 1.  [Tutorial] Offload RAP WhitelistDB to Clearpass
    Posted Feb 03, 2015 12:33 AM
    This tutorial goes over how to create a whitelistDB on the clearpass server via Local Users DB. There are a few custom SQL scripts that will be performed while obtainging attributes from the Local Users. RAP's can be staged by non-network admins with ease of provisioning via clearpass.
    Local User entry must contain the mac address for Username / Password along with the following items to be classified and pass radius VSA's to the mobility contorller.
    - AP-Type:
    - AP-Group:
    - AP-Name:
    Configure Mobility Controller to use External Radius (Clearpass)
    Create SQL Authentication Source
    This custom filter will allow us to derive attributes from the Local Users DB and use these attributes within an authorization source via the services policies.
    select user_id, tag_name, tag_value from tips_local_users_attr_view where
    ((user_id = '%{Radius:IETF:User-Name}') and (tag_name like '%AP-Type%'))
    ((user_id = '%{Radius:IETF:User-Name}') and (tag_name like '%AP-Name%'))
    ((user_id = '%{Radius:IETF:User-Name}') and (tag_name like '%AP-Group%'))
    select user_id, name from tips_local_users_attr_view where
    Roles
    The following 2 roles will need to be created, the RAP role is applied as a default role to the local users, and the RAP Authenticated role is derived from a successful role process via the service policies
    Role Mappings
    The following role mapping will allow us to validate the MAC address of the IETF:Username via the radius request and associate it with the Local Users DB. We will also be confirming some of the following attributes.
     - Enabled
     - Client-MAC-Vendor
     - AP Type: contains AP (this can be changed by users preference)
     - AP Group: exists
     - AP Name: exists
    If not all of these values are true the device will not pass the role mapping and not receive the role RAP Authenticated. Also another note for why AP Type attribute was created is so you can have other MAC authentication services applied in the config without causing conflicts.
    ** Note ** If you have any issues adding mappings due to attributes, you can update the attributes under the administration section.
    Enforcement Profiles
    It will only be necessary to create the [RAP whitelistDB - Return VSA] profile (since this data will be passed to the mobility controller). You can also create the RAP Update Endpoints DB profile as well. Since our users will be populated and used via MAC Authentication from the Local Users, we dont necessarly need to pupluate date in Endpoints.
    [RAP Update Endpoint DB]
    Enforcement Policy
    Without a successful role mapping from earlier we will fail the enforcement policy causing us to fail the radius request and get dropped.
    For another layer of security you can always add the [User Authenticated] role to the rules page. This way the user will need to have [RAP Authenticated] + [User Authenticated] to pass the policy page.
    Services
    We will apply all of our customized settings under this service profile, we will also be looking for the Client MAC Vendor whish is displayed to us via the radius request. This will also rule out any non-aruba device that may not be needed to be classified for this service policy. We will also be selecting our Local Users DB for MAC Authentication, and using our custom sql filters for the authorization settings.
    Create Local USer (RAP)
    In the following example I have removed half of the MAC address. Esentially you can use uppercase / lowercase for the mac address and the password will be the same as the username.
    Access Tracker Output
    After completing all of the necessary configs in the clearpass server we should be able to review access tracker and see our authetnicated user. We will also be reviewing the Authorization Attributes section under Input as this is where many of our custom options have came from.
    The output of the "ap database" shows that we have received the following VSA's to the clearpass server.
