Network Management
[TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
  • 1.  [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 18, 2014 09:14 PM
    It is a little known fact that you can enable single-sign on between Airwave and your controllers.  The idea is that you use Airwave as a central point of management, but if you need to get into a controller, Airwave should be able to automatically log you in to it with the correct privileges, without you having to re-enter your username and password.  All you need to configure this is:
    (1) Root Access on Airwave to make the configuration change
    (2) Correct Admin/Root level and enable credentials entered into Airwave for that Controller.
    Here is how it works.  In Airwave, go to AMP Setup > Roles.  There you will see all of the Roles of Users that could login to AMP.  If you edit the Role, the Aruba Controller Role parameter controls what privileges on the Aruba Controller a user in AMP that Clicks on Open Controller WebUI will have.  The Aruba Controller Role parameter by default is set to disabled.  In the screenshot below, we changed it to root, which means that anyone who logs into Airwave who has the Admin role, will be able to click on the Open Controller WebUI (when monitoring a controller) and be redirected to the controller's page without logging in.  You can also set the paramater to read-only for Airwave admin roles that you only want read-only access to your controller with SSO.
    Enable Single Sign On in AMP
    After looking at a controller in Airwave, I can open up the Controller's dashboard to any menu item without having to login to the controller:
    Under the hood:
    How is works, is that Airwave will look at the Aruba Controller Role parameter of the currently logged in management user and if it is disabled, it will do nothing.  If it has a root or read-only role, it will execute a command, "allow-sso <username> <controller admin role>" on the controller.  The controller will spit back a special URL that airwave would need to connect to the controller over https to gain those permissions.  It redirects the Airwave user to that special URL and the controller grants the permissions.
    You can tell if a user has logged in to a controller with Airwave SSO by typing "show audit trail":
    show audit-trail
    Jan 18 20:04:25  fpcli: USER:admin@192.168.1.6 COMMAND:<allow-sso "admin" "root" > -- command executed successfully
     You can also tell if a SSO user is currently logged in by typing "show loginsessions:
    (192.168.1.3) #show loginsessions
    Session Table
    ID  User Name  User Role  Connection From  Idle Time  Session Time
    1   admin      root       192.168.1.76     00:00:00   00:00:02
    2   admin_sso  root                        00:02:20   00:06:50
  • 2.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 18, 2014 11:12 PM
    Hello Collin
    I got this question asked yesterday hahah
    The thing is that i have been trying this with no luck...
    I did enable the feature in the Airwave like this
    After that i tried logging in using the Airwave
    I get prompted to put my user and password...
    I got Airwave 7.7.8
    Trying with a Aruba controller 6.3.1.2
    Is there anything im missing Collin?
    Cheers
    Carlos
  • 3.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 18, 2014 11:24 PM
    Maybe im missing this part
    The only device credential i find are the telnet and enable secret ones here
    If those are not the ones that you are referring
    Can you please point me where they are?
    Cheers
    Carlos
  • 4.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 05:50 AM
    That is correct.  On the commandline of your controller (#), type admin-sso ? and see if it autocompletes.
  • 5.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:12 AM
    It does not autocomplete
    Is not in the command list!
  • 6.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:19 AM
    Sorry.  It is "allow-sso".  It is there in the command list.
  • 7.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:20 AM
    yeah it autocompletes
    I did what it says here
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Single-Sign-On/td-p/75732
    Which was that command but i still get to promt of the login
  • 8.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:21 AM
    this was the output
    (Office_Alternetworks) #allow-sso admin root
    66af997b-b9b5-40ca-95ee-7219fef2902c
  • 9.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:30 AM
    Do you see that command executed in the Audit trail by Airwave?  What version of Airwave, by the way?
  • 10.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:34 AM
    (Office_Alternetworks) #show audit-trail login
    Dec 21 15:34:57  cli[1576]: USER: admin has logged in from 172.16.3.222.
    Dec 21 15:34:59  cli[1576]: USER: admin connected from 172.16.3.222 has logged out.
    Dec 21 15:35:19  webui[1494]: USER: admin has logged in from 172.16.3.222.
    Dec 21 15:35:26  cli[1576]: USER: admin connected from 172.16.3.222 has logged out.
    Dec 21 15:35:41  cli[1576]: USER: admin has logged in from 172.16.3.222.
    Dec 21 15:36:09  cli[1576]: USER: admin connected from 172.16.3.222 has logged out.
    Dec 21 15:36:33  webui[1494]: USER: admin has logged in from 172.16.3.43.
    Dec 21 15:37:41  fpcli: USER: admin has logged in from 172.16.3.222.
    Dec 21 15:37:44  fpcli: USER: admin connected from 172.16.3.222 has logged out.
    Dec 21 15:37:56  fpcli: USER: admin has logged in from 172.16.3.222.
    Dec 21 15:38:00  fpcli: USER: admin connected from 172.16.3.222 has logged out.
    Dec 21 15:39:58  webui[1494]: USER: admin has logged in from 172.16.3.122.
    Dec 22 04:18:23  fpcli: USER: admin has logged in from 172.16.3.222.
    Dec 22 04:18:55  fpcli: USER: admin connected from 172.16.3.222 has logged out.
    Dec 23 04:18:23  fpcli: USER: admin has logged in from 172.16.3.222.
    Dec 23 04:18:54  fpcli: USER: admin connected from 172.16.3.222 has logged out.
    Dec 23 08:45:11  webui[1494]: USER: admin has logged in from 172.29.0.26.
    Dec 23 12:15:46  webui[1494]: USER: admin has logged in from 172.29.0.26.
    Dec 23 12:16:38  fpcli: USER: admin has logged in from 172.29.0.26.
    Dec 23 12:33:31  fpcli: USER: admin connected from 172.29.0.26 has logged out.
    Dec 24 04:18:23  fpcli: USER: admin has logged in from 172.16.3.222.
    Dec 24 04:18:54  fpcli: USER: admin connected from 172.16.3.222 has logged out.
  • 11.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:35 AM
    172.16.3.222 is the airwave ip address
  • 12.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:39 AM
    Does just "show audit-trail" show airwave executing the command?  What version of Airwave?
  • 13.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:40 AM
    Airwwave 7.7.7
  • 14.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:42 AM
    the lastest entries i see in show audit trail are
    Jan 19 09:09:32  fpcli: USER:admin@10.10.100.2 COMMAND:<local-userdb-ap del all > -- command executed successfully
    Jan 19 09:15:30  fpcli: USER:admin@10.10.100.2 COMMAND:<allow-sso "admin" "root" > -- command executed successfully
  • 15.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:44 AM
    And ArubaOS 6.3.1.2?  What controller model?   Okay, we will get it checked out.
  • 16.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:51 AM
    Controller mode is master
    Just to review Collin to see if i do everything i need to
    1. I went to the airwave and put aruba controller role root on the roles on the admin role in the airave like thissso1.PNG
    2. After that i went to the controller and issue the command "allow-sso"
    3. I then try going to the airwave and open the controller GUI by going here sso2.PNG
    It didnnt work
    Just to review to see if i didnt miss anything
    Controlller version  6.3.1.2 on Master Role, and the controller model is 620
    Airwave version 7.7.7.7
    Cheers
    Carlos
  • 17.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 09:54 AM
    Can you upgrade to 7.7.8 and try?  That is what I have working right now.
  • 18.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 10:00 AM
    sure
    let me upgrade it
    After that ill come back to you
    Cheers
    Carlos
  • 19.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 10:11 AM
    Welll there is something weird happening
    im trying to start_amp_upgrade -v 7.7.8 and nothing happens...
    It does accept the command as it does not send me any error... but it does nothing...
    Aw well ill do an offline upgrade  hope that works well :)
    Cheers
    Carlos
  • 20.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 11:40 AM
    it keep happening the same even with the upgrade
    It must be something silly im missing or it just dont work with 620 model?
    Anything else i can check out?
    Cheers
    Carlos
  • 21.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 11:42 AM
    If you can execute the command on the 620, it should work on the 620. You should see Airwave executing the command in the audit trail. If not, we should open a case to determine why Airwave is not SSHing into the controller to set that.
  • 22.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 11:50 AM
    Well i did ran a command with the airwave but a cli command and i see this on the controller with the audit trail command
    Jan 19 11:46:15  fpcli: USER:admin@172.16.3.222 COMMAND:<no paging > -- command executed successfully
    Jan 19 11:46:15  fpcli: USER:admin@172.16.3.222 COMMAND:<encrypt disable > -- command executed successfully
     The thing is that when i try on the airwave running the tab of performance or any tab of the web gui of the controller i see nothing in the audit trail....
    Guess i would need to open a support case?
  • 23.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 12:02 PM
    Do this:
    config t
    audit-trail all
    Then try to get to the controller from AMP and see if the command is run.
  • 24.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 02:43 PM
    nothing...
    I did show audit trail all like you said
    And i can even see the last command i executed
    Jan 19 14:41:15  fpcli: USER:admin@10.10.100.2 COMMAND:<show audit-trail > -- command executed successfully
  • 25.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 19, 2014 04:15 PM
    Okay.  Looks like Airwave is not logging in to create the session.  Let us check and get back to you.
  • 26.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 21, 2014 12:44 PM
    Granted you've already passed the allow-sso command on the controller, there's 2 settings in AMP to check for Single Sign-On.
    Enable Single Sign-On from AMP
    1. AMP Setup -> Authentication tab -> Single Sign-On -> enable single sign-on
    Then, you'll also want to make sure that the AMP User has a specified Aruba Controller role.
    2. AMP Setup -> Roles -> edit role -> AMP Controller Role -> by default this is 'disabled'
    Once those 2 settings are valid, the controller's IP link should take you directly into the Controller's UI (showing the front dashboard page for performance).  And the dropdown for controller quick links should take you to the appropriate pages as well.
  • 27.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 21, 2014 06:46 PM
    Rob you did it!!!
    I didn tknow you had to enable that on the authentication tab under amp setup
    Now i can log in throuhgh the airwave, and i can see log out admin_sso!
    Guess thats that fastest way to know you are logging through sso :)
    Cheers
    Carlos
  • 28.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 10:59 AM
    Just a quick note, Colin did have that screenshot in his tutorial regarding the SSO on AMP. ;)
  • 29.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 11:19 AM
    I dont remenber looking that on the manual at that time when i tried... oh well..
    The thing is that is working
    Cheers
    Carlos
  • 30.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 11:20 AM
    I did not have that last screenshot there on the initial article.  I corrected it after Rob posted his.
  • 31.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 11:22 AM
    Ah well that explains that :)
    Cheers
    Carlos
  • 32.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 11:35 AM
    Just trying to help ;)
    definitely explains that...lol
  • 33.  RE: [TUTORIAL] Single Sign-On (sso) to Aruba Controllers from Airwave (ArubaOS 6.3 and Above)
    Posted Jan 22, 2014 11:45 AM
    Didn't know how to annotate the change.  Thanks for helping.
