[Tutorial] Tweaking your controllers in 6.3 #mhc
  • 1.  [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 10, 2014 01:44 PM
    Hi!
    I've created a tutorial for configuring and verifying the most popular features that are new or improved in Aruba OS 6.3. I've tried to make everything as understandable and easy as possible and tried to use the web UI as much as possible for it to be useful for a wider audience.
    The topics I cover are:
    • Centralized licensing
    • New redundancy model "Fast Failover"
    • Client match
    • Monitoring with "AMON"
    I've attached a .PDF version and a .docx version of the tutorial together with the user guides for Aruba OS 6.3. Good luck with your 6.3 configuration and if you found the tutorial useful, please consider giving me a +1 kudos for it :)
    Cheers!
    Chris
    EDIT1: It seems the attachments arn't visible in the app. I'll try to get the material into the post itself tonight again otherwise I'll make them look a bit better at least (they were formatted for the post).
    EDIT2: Since I couldn't fit the material into this post I've remade the format of the documents attached so it's better formated and easier for you to read. I've also corrected some spelling errors :) Have a nice weekend!
    #6.3
    Attachment(s)
    pdf
    ArubaOS_6.3.xUG.pdf   23.04 MB 1 version
    pdf
    ArubaOS_6.3xCLI.pdf   6.07 MB 1 version
  • 2.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 10, 2014 02:11 PM
    Great topic. Could you add the pdf material into the post?
  • 3.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 10, 2014 02:27 PM
    Thank you Srynearson! It's already there, the .pdf and the .docx. Isn't it?
    It would be greatly appreciated if someone could help me get the material into the post instead of the attached files.
    Chris
  • 4.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 10, 2014 07:57 PM
    It doesn't show up at least in the mobile version of airheads.
  • 5.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 10, 2014 09:00 PM
    where are the file to, download?
  • 6.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 11, 2014 12:39 AM
    current mobile app does not support attachment. must view in browser. sorry guys. It is on the wish list.
  • 7.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 11, 2014 06:35 PM
    thanx Mewn!
  • 8.  RE: [Tutorial] Tweaking your controllers in 6.3 #mhc
    Posted Mar 14, 2014 11:51 AM
    I've updated the format of the attached files as this seem to be the permanent solution for this tutorial. Enjoy and have a nice weekend!
    Chris
