Wired Intelligent Edge
last person joined: 10 hours ago
Two AP MACs showing up on same switch port
  • 1.  Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 11:14 AM
    I'm showing the MAC address of two separate APs (IAP 105s) on the same switch port as below:
    (MAST-MDF) # show mac-address-table | include 24:de:c6:c3:e5:6c
    24:de:c6:c3:e5:6c Learnt 0422 GE1/0/0
    24:de:c6:c3:e5:6c Learnt 0472 GE1/0/0
    (MAST-MDF) # show mac-address-table | include 9c:1c:12:c9:87:2f
    9c:1c:12:c9:87:2f Learnt 0472 GE1/0/0
    The two APs are connected to separate ports on the same switch in a stack of three switches. Any idea why this would be and if there's a way to correct it?
    Thanks.
  • 2.  RE: Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 11:22 AM
    Jkoelker,
    What ports are the APs actually on? It is interesting to see that one of the MAC addreses is being learned on a different VLAN (422). What VLAN should they be on? It looks like a loop of some type.
    Best regards,
    Madani
  • 3.  RE: Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 11:28 AM
    Hi, Madani -
    24:de:c6:c3:e5:6c is connected on port 1/0/0
    9c:1c:12:c9:87:2f is connected on port 1/0/45
    The APs should reside on vlan472 - vlan 422 is a user-access vlan.
  • 4.  RE: Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 11:58 AM
    Hi Friend,
    Which Image version you are using in MAS ? for reconfirm, APs are directly connected to the MAS right ?
    please clarify.
  • 5.  RE: Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 12:06 PM
    Out at site now - have re-booted AP by power-cycling and it is unable to boot normally. Looks like it may have failed.
  • 6.  RE: Two AP MACs showing up on same switch port
    Posted Jan 06, 2015 02:28 PM
    Can you console into it?
    I'm still trying to figure out how that MAC would appear on a different port. It's indicative of a loop condition and not necessarily a code issue on the MAS. One thought was that the IAP was using the other IAP as a gateway but that would require things like MESH or wifi uplink to be enabled.
    Best regards,
    Madani
