Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Two authentications for VIA access
  • 1.  Two authentications for VIA access
    Posted Oct 04, 2016 04:46 AM
    Hello all,
    I have configured VIA on my controller and it work well. However I have to authenticate two times on VIA with AD credentials.
    Is it normal?
    Thanks your for your answers
  • 2.  RE: Two authentications for VIA access
    Posted Oct 04, 2016 06:44 AM
    What OS is this?
    You have to authenticate once to download the profile initially and then to connect with the VPN connection.  After that, you should only have to authenticate once.
    Do you have VIA configured to automatically use your logged in domain credentials?
  • 3.  RE: Two authentications for VIA access
    Posted Oct 04, 2016 06:54 AM
    Hello Joseph,
    ArubaOS 6.4.4.1
    VIA version 2.3.4.0 on Windows 10.
    After each reboot, I have to enter my credentials to authenticate on VIA.
    The following paramaters are enabled:
    Enable Domain Pre-connect
    Use Windows Credentials
    Best regards
  • 4.  RE: Two authentications for VIA access
    Posted Oct 04, 2016 07:17 AM
    Turn off domain preconnect
  • 5.  RE: Two authentications for VIA access
    Posted Oct 04, 2016 07:29 AM
    Thanks you Super Joseph,
    It is working now.
    Regards
