Two Controllers
  • 1.  Two Controllers
    Posted Apr 04, 2013 08:51 AM
    our controller is running out the number of ap it can support hence we will need to purchase a 2nd controller. Other than increased number of ap it can support is there any other advantages of having 2 controller?
  • 2.  RE: Two Controllers
    Posted Apr 04, 2013 09:07 AM
    It all depends how you will use the 2nd controller and what model you purchase.
    Direct advantages are
    • Redundancy (Master-Local for example)
    • Load balancing of APs between the two controllers
    You can read through the following VRD to give you some insight
    http://www.arubanetworks.com/wp-content/uploads/CampusVRDV8_20110913.pdf
    What are you running with now?
  • 3.  RE: Two Controllers
    Posted Apr 04, 2013 09:14 AM
    It really depends on the need of your campus and the amount of APs you are currenlty managing and the future growth , here's some examples :
    - To balance APs between the two that way your traffic doens't go to just one controller and also if one fails not every AP will be impacted.
    - Also if you need to perform maintenance on one of the controller you could move the APs over to the other one while you make changes
    - If you have enough licenses on each controller you can have those serve has active-backup/active-backup
    Hopes this helps
