The internal networks for example the corporate network is being routed by the core switch
The guest network its a vlan and network that just exist on the controller
I managed to make it work but well... that killed my raps... in my laboratory....
Since
Routes on the controller
Codes: C - connected, O - OSPF, R - RIP, S - static
M - mgmt, U - route usable, * - candidate default
Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
Gateway of last resort is 10.10.50.1 to network 0.0.0.0 at cost 1
S* 0.0.0.0/0 [1/0] via 10.10.50.1*
S 10.25.143.0/24 [1/0] via 172.16.3.1*
S 172.16.2.0/24 [1/0] via 172.16.3.1*
S 172.16.10.0/24 [1/0] via 172.16.3.1*
S 172.16.20.0/24 [1/0] via 172.16.3.1*
S 172.29.0.0/24 [1/0] via 172.16.3.1*
C 172.16.3.0 is directly connected, VLAN10
C 10.10.50.0 is directly connected, VLAN999
The vlan 999 is the vlan that connect to the guest internet which is directly attached to the controller
Now you see a few networks for example 172.16.20.0/24 those are being routed by the core switch
Everything works fine but then... i got these raps in which they will connect to the public ip address of the corporate terminate on the controller and will aim to go out through the guest network internet cause of the default ip route i had to change to make it work...
I though i foudn a way to do it but now my remotes are missing unless i add to the route table pointing to the corporate core switch the public ip address of the rap... which is no good...
Now im thinking another way....
Ill have to trunk the guest vlan to the corporate L3 and make them do the job.... i mean using policy base route that the controller does not support...
