Two Factor Authentication
  • 1.  Two Factor Authentication
    Posted Jul 09, 2020 09:24 AM
    Hi Team,
    Would like to know if we can try Two Factor Authentication for controller login.
    Eg:
    We need to login to controller
    If we enter login username >> it should go to a server which will provide OTP or token  to user
    Using that token, we need to login to controller GUI
    Is the above possible with external server? If yes, what should we do in controller?
    Is it possible without external using controller alone.
    VB.
  • 2.  RE: Two Factor Authentication
    MVP GURU
    Posted Jul 11, 2020 12:33 PM
    I believe you should be able to send your radius requests for administrative login to a RADIUS proxy, and then to your two-factor. Username and then password would be the token.
  • 3.  RE: Two Factor Authentication
    Posted Jul 12, 2020 01:41 PM
    Hi Dustin,
    Thank you! Can we achieve this with clearpass and this token + username login - 2 factor auth is for controller GUI login. Is that possible?
  • 4.  RE: Two Factor Authentication
    Posted Jul 28, 2021 08:31 PM
    Hi VB,
    Did you ever get this working? I have to do this on some controllers as well.
    Steve
