Two IAP-205 with different settings: which settings will be overwritten?
  • 1.  Two IAP-205 with different settings: which settings will be overwritten?
    Posted Mar 06, 2015 10:35 AM
    I'm just starting out with Aruba Wi-Fi and got a question regarding automatic provisioning of Access Points.
    I have two IAP-205, I have connected them and set up all the settings that I need, on Instant config panel.
    Then I powered on just one of them, AP2, and changed the settings.
    If now I connect both of them to the network and power on, which settings will be used for the Wi-Fi? Old ones (from AP1) or new ones (from AP2)?
    Thanks!
  • 2.  RE: Two IAP-205 with different settings: which settings will be overwritten?
    Posted Mar 06, 2015 10:49 AM
    If AP2 stays up after you made that change then when AP1 comes up the new changes will be pushed to the AP1 from AP2
  • 3.  RE: Two IAP-205 with different settings: which settings will be overwritten?
    Posted Mar 06, 2015 11:22 AM
    Alright, thank you!
    And I guess if I turn them on at the same time, the random configuration will be kept..
  • 4.  RE: Two IAP-205 with different settings: which settings will be overwritten?
    Posted Mar 06, 2015 11:25 AM
    At that point it will depend on each IAP came up faster and that will determine which one becomes the master
  • 5.  RE: Two IAP-205 with different settings: which settings will be overwritten?
    Posted Mar 06, 2015 11:32 AM
    Great, got it!
