two ip address in customer device
  • 1.  two ip address in customer device
    Posted Dec 16, 2014 08:26 PM
    hi experts ,
    one device in customers enviroment is special, it must bridge its wireless network card and its cable network card to connect with server in network.  when this device connect to aruba ap ,it could get ip address ,from network ,it could ping device wireless ip address successfully but it can not ping bridge ip address of device .
    If the device connect to other household ap such as tp-link ,both ip address could be ping ,and it work well , my question is what special confiugration  in aruba controller block to ping the second ip address in the end device.
    Thanks.
  • 2.  RE: two ip address in customer device
    Posted Dec 16, 2014 09:00 PM
    is this relate to this command in show running
    firewall deny-inter-user-bridging
  • 3.  RE: two ip address in customer device
    Posted Dec 16, 2014 10:25 PM
    An enforce DHCP setting would prevent this.  ACLs in the user role could too.  First check whether you can ARP the bridged address to bisect the problem.
  • 4.  RE: two ip address in customer device
    Posted Dec 16, 2014 11:18 PM
    One thing you could do is change the validuseracl to only allow the segments you want to and deny the rest
  • 5.  RE: two ip address in customer device
    Posted Dec 17, 2014 10:40 AM
    hi Colin
    turn off broadcast filter all and broadcast filter arp in the vap profile.
    regards
    -jeff
  • 6.  RE: two ip address in customer device
    Posted Jan 14, 2015 09:07 PM
    Thanks ,problems solved after turn those option off.
