Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
  • 1.  Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 07:11 AM
    Hi Guys,
    I have to questions :) ( I just want to be sure)
    1. When deploying instantAP with 802.1x in front of external radius - Do i only need to add the VC address to the radius server as NAS-IP ?
    2. What if the VC is down and another unit becoming the MASTER ? (is it using the same NAS-IP?)
    Please advise,
    Thanks in advance,
    Me
  • 2.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 07:19 AM
    With Instant you can either add each physical IP of each IAP as RADIUS clients, or enable Dynamic RADIUS Proxy; by which all IAPs will use the VC IP.  You have to have a satic VC IP defined for this to work.
  • 3.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 07:21 AM
    OK Thanks :)
    So i use virtual controller ip option + radius proxy - then i will only need to add the virtual controller ip to the raidus as nas-ip
    i understood right?
  • 4.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 07:22 AM
    Exactly.  Single NAS Client on RADIUS; all IAPs in cluster will use the static VC address as the NAS IP.
  • 5.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 07:26 AM
  • 6.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 10:15 AM
    Yes, but instead use DRP
  • 7.  RE: Two short questions : Deploying instantAP with 802.1x (1.only VC as nas-ip? 2.When VC is down?)
    Posted May 31, 2014 03:01 PM
    Marcosel, drp = dynamic radius proxy, in order to use this option , u also need the use the virtual controller IP.
