Two SSIDs and guest portal
  • 1.  Two SSIDs and guest portal
    Posted May 23, 2018 09:41 AM
    Hey everyone
    I have two SSID on my Aruba Controllers with are directed to clearpass guest portal. This setup was working on a older setup with our 6003 controller. Now running 2x7220.
    One of the SSIDs are going to be assigned to Endpoint:Guest Role ID=2 and the other to Endpoint:Guest Role ID=3.
    This is because access is one day for ID=2 and one month for ID=3.
    My problem now is that under computed attributes both values show ID=2.
    The controllers are sending out the same groups for both SSIDs, are this were the Endpoint:Guest Role ID=2 are comming from ? Feel kind of stupid for not figuring this out )-:
  • 2.  RE: Two SSIDs and guest portal
    Posted May 23, 2018 09:43 AM
    Why not use a single SSID?
  • 3.  RE: Two SSIDs and guest portal
    Posted May 23, 2018 09:45 AM
    Guest are just using phone number and SMS code for authentication. How would I seperate them ?
