Two SSIDs & Two LDAP Groups
  • 1.  Two SSIDs & Two LDAP Groups
    Posted Aug 01, 2012 01:01 PM
    Hey Guys,
    I'm currently trying to figure out the best way to configure have two different SSIDs with one being for a specific LDAP group.  We are currently not using RADIUS (that will be done in the future), and are authenticating directly to MS AD.  I currently have an SSID that anyone with an LDAP account can access, but I have another SSID that is to be used by a specific group.  At the moment, the only way I can see doing this is to copying the existing LDAP servers and filtering for the desired group.  Is there any other way to do this?  Thanks.
    Controller 3200
    OS 6.1.3.1
    #3200
  • 2.  RE: Two SSIDs & Two LDAP Groups
    Posted Aug 01, 2012 02:43 PM
    Why not just have a single SSID and change the role based on the "memberOf" attribute?
  • 3.  RE: Two SSIDs & Two LDAP Groups
    Posted Aug 01, 2012 02:56 PM
    Hey Cjospeh,
    Currently our network design has a vlan for each SSID.  The Guest SSID/Vlan is used on both wired and wireless.
  • 4.  RE: Two SSIDs & Two LDAP Groups
    Posted Aug 01, 2012 03:17 PM
    Are your two different sets of users in a group or in separate containers (OUs)?  if they are in separate containers, you can have two different LDAP server definitions;  one where the base-dn is the OU of the first container and one where the second base-dn is the OU for the second container of users.
    Will that work?
  • 5.  RE: Two SSIDs & Two LDAP Groups
    Posted Aug 01, 2012 04:37 PM
    Hey Cjoseph,
    The Guest SSID can be used by anyone with an LDAP account.  The other SSID will just be a single group, but its users will be in different OUs.  I originally thought of a creating a second LDAP definiation, but wasn't sure if there was another (better) way to do it.  I will go ahead with that method.
    Thanks.
