Two step authentication
  • 1.  Two step authentication
    Posted Mar 01, 2012 03:30 AM
    Hello! I'm looking for a guide on how to configure IKEv2 for the via client. I would like to achive a two step authentication with user cert first and then user credentials. The second best thing would to be machine cert and then either user cert or user credentials. Also I would like to know where I can find the configurationfile for the connection created in the client. Can any of you point me in the right direction to proceed? Thanks in advance.
  • 2.  RE: Two step authentication
    Posted Mar 01, 2012 12:16 PM
    Using IKEv2 i dont think you can achieve what you are trying to do. However, if you use IKEv1 then you can use user certs for the IKEv1 phase 1 authentication and then use user credentials for XAUTH. With IKEv2 it just a one authentication, either user certs, EAP-TLS or EAP-PEAP
    Sathya
