ArubaOS 8.6.0.4 (cluster)
We have a RAP-3WNP in use at a member of staff's house. Both its available wired ports are configured to tunnel back to the controller on one of our VOIP VLANs, the ports are configured as trunks with the VOIP VLAN tagged, each phone has also been manually configured with the VOIP VLAN.
This appeared to work - the phones can register (so can talk to Call Manager), and the member of staff can call them from other phones (eg his mobile) successfully. However he can't call from one of the two phones to the other (the phone rings but there is no audio when he picks up). I believe once you pick-up the phones communicate directly with each other P2P, so it seems like this must be some sort of traffic blocking problem possibly in the AP (they are on the same VLAN).
How can I tell if an ACL is being applied here? I can't see anything in the wired-port or wired-ap profiles. There is an AAA profile but I can't see any info about what role the phones might have because they aren't in the user table. Can anyone give any advice about troubleshooting wired clients on RAPs like this?
Guy
