UAP-345 Clear OS Can't boot WebUI
  • 1.  UAP-345 Clear OS Can't boot WebUI
    Posted Jan 31, 2019 01:50 AM
    Hello guys
    I have a UAP-345
    and i boot into apboot mode type clear.
    Now ap can not boot normally.
    how would i reinstall the image?
    Thank you
  • 2.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Jan 31, 2019 02:56 AM
    Do you have the output of the console?
  • 3.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Jan 31, 2019 03:11 AM
    Hello
    The console output is following:
    HELO
    5.0202-1.0.38-161.122
    CPU0
    L1CD
    MMUI
    MMU8
    CODE
    ZBBS
    MAIN
    NVRAM memcfg 0x41427
    MCB chksum 0xa259e84b, config 0x41427
    DDR3-1600 CL11 total 512MB 2 16bits part[s] %1 SSC
    DDR test done successfully
    Loading image 0...
    Validating image 0...
    Uncompressing image 0...
    Booting image 0...
    APBoot 2.3.0.8 (build 62499)
    Built: 2017-11-27 at 16:00:23
    Model: AP-34x
    DRAM: 512 MiB
    NAND: ECC BCH-4, ONFI, Manuf ID: 0xef, Chip ID: 0xf1 (Winbond W29N01HV), page size: 2048, OOB size: 64, device size: 128 MiB
    PCIE1: link up
    PCIE2: link up
    Power: 802.3af POE
    In: serial
    Out: serial
    Err: serial
    Net: eth0, eth1
    Radio: bcm43465#0, bcm43465#1
    Reset: cold
    FIPS: passed
    Hit <Enter> to stop autoboot: 2  0
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot> print
    autoload=n
    autostart=yes
    baudrate=9600
    boardname=Masterson
    bootargs=console=ttyS0,9600n8 rdinit=/sbin/init ubi.mtd=pdata ubi.mtd=aos
    bootcmd=boot ap
    bootdelay=2
    bootfile=arm64.ari
    ethact=eth0
    ethaddr=38:17:c3:c1:7f:ba
    mtddevname=aos
    mtddevnum=3
    mtdids=nand0=nand0
    mtdparts=mtdparts=nand0:3m(apboot),512k(panic-dump),2m(pdata),-(aos)
    os_partition=1
    partition=nand0,3
    servername=aruba-master
    stderr=serial
    stdin=serial
    stdout=serial
    Environment size: 472/65531 bytes
    apboot>
    apboot>
    apboot>
    apboot> boot
    Booting OS partition 1
    Checking image @ 0x2000000
    Invalid image format version: 0xffffffff
    Checking image @ 0x0
    Setting SGMII Calibration value to 0xb
    Found external PHY 84880 (B0) (PHY_ID: ae025159)
    Loading PHY firmware for device 0x308001e ...
    Done. Firmware Size = 106882:0x1a182 bytes, Simple Checksum: 0x7a7d0d68
    PHY successfully came out of reset
    PHY Firmware is loaded with Good CRC.
    PHY Fimware Version(Main.Branch.Build): 2.01.00
    PHY Firmware Loaded Successfully
    uTimeOut for status = 1
    Energy detection is used as SFP module insertion detection
    eth0: link up, speed 100 Mb/s, full duplex
    DHCP broadcast 1
    *** Unhandled DHCP Option in OFFER/ACK: 224
    DHCP IP address: 192.168.1.110
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.1.99
    DHCP DNS server: 208.91.112.53
    DHCP DNS domain:
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master. to 208.91.112.53
    DNS request 2 for aruba-master. to 208.91.112.53
    DNS request 3 for aruba-master. to 208.91.112.53
    DNS request 4 for aruba-master. to 208.91.112.53
    Retry count exceeded; starting again
    eth1 link is down
    DHCP broadcast 1
    DHCP DNS domain:
    ADP broadcast 3
    ADP multicast 4
    ADP broadcast 4
    ADP multicast 5
    ADP broadcast 5
    Abort
    apboot>
    apboot>
    apboot>
    apboot>
  • 4.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Jan 31, 2019 03:16 AM
  • 5.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Jan 31, 2019 08:26 PM
    The instruction seems to have no effect.
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot> print
    autoload=n
    autostart=yes
    baudrate=9600
    boardname=Masterson
    bootcmd=boot ap
    bootdelay=2
    bootfile=arm64.ari
    ethact=eth0
    mtddevname=aos
    mtddevnum=3
    mtdids=nand0=nand0
    os_partition=1
    partition=nand0,3
    stderr=serial
    stdin=serial
    stdout=serial
    uap_controller_less=1
    Environment size: 496/65531 bytes
    apboot>
    apboot>
    apboot> save
    Saving Environment to UBI...
    Writing to UBI... done
    apboot>
    apboot>
    apboot>
    apboot>
    apboot> boot
    DHCP broadcast 1
    DHCP DNS domain:
    ADP multicast 6
    ADP broadcast 6
    ADP multicast 7
    ADP broadcast 7
    ADP multicast 8
    eth1 link is down
    DHCP broadcast 1
    DHCP DNS domain:
    ADP broadcast 8
    ADP multicast 9
    ADP broadcast 9
    ADP multicast 10
    ADP broadcast 10
    Abort
    apboot>
  • 6.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Feb 01, 2019 05:04 AM
    Did you try executing the factory reset procedure?
  • 7.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Feb 05, 2019 03:53 PM
    If you can put in a DNS entry for aruba-master to point to one of your controllers it should connect and pull down another image.
    Brady
  • 8.  RE: UAP-345 Clear OS Can't boot WebUI
    Posted Feb 10, 2019 08:54 PM
    Hello
    I use reset button to factory reset , and it seems to have no change.
  • 9.  RE: UAP-345 Clear OS Can't boot WebUI
