Ubuntu 16.04 error connecting to 802.1x
  • 1.  Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 02:43 PM
    Hi
    I am testing ubuntu 16.04 and getting error connecting to IAP.
    I have an 802.1x network with mac authentication. It was working before on ubuntu 14.04 .
    It seems some kind of not asking for certificate to run or something. Does this help?
    cli[1712]: <541004> <WARN> |AP 94:b4:0f:cd:33:98@192.168.250.27 cli|  recv_stm_sta_update: receive station msg, mac-c4:d9:87:39:f4:90 bssid-94:b4:0f:53:39:91 ssid-GeRal.
    May 10 19:21:34  radiusd[4208]: rlm_eap: SSL error unknown error number
    May 10 19:21:34  radiusd[4208]: SSL: int_ssl_check() WANT_READ seen. Returning 1
    May 10 19:21:34  radiusd[4208]: radius_pairmove: 959: why request for zero mem?
    May 10 19:21:34  stm[1740]: VLAN_HIGHER_PRECEDENCE_THAN_STORED: 1064: vlan_rule_index=ff, sap_sta->vlanhow=ff, precedence_result=1
    May 10 19:21:34  stm[1740]: __HIGHER_PRECEDENCE_COMPARE: 1041: matched_rule_index=37fff, sap_sta->acl_rule_index=0, precedence_result=1
    May 10 19:21:34  stm[1740]: stm_send_sta_update: Sending sta update msg to CLI0, mac='c4:d9:87:39:f4:90'
    May 10 19:21:34  stm[1740]: stm_start_acct_for_post_1xauth_user: 15815: ip not ready for sta 'c4:d9:87:39:f4:90'
  • 2.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 03:02 PM
    What RADIUS server are you using ?
  • 3.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 03:43 PM
    Hi
    I am using internal Iap Virtual controller radius.
  • 4.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 04:01 PM
    Ok, I had similar issues with Windows 10 using IAP's internal RADIUS server (which is an instance of  FreeRADIUS).
    Turns out that when I upgraded to version 6.4.4.3.4.2.2.0, it solved my problem. I'm sure it would worth trying it (in a lab environment) if you have a version prior to this. Even if it's not written in the release note, they clearly did modifications to internal FreeRADIUS server (maybe adding TLS 1.2 support perhaps).
    Also, a wireshark capture would be great.
  • 5.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 20, 2016 09:23 AM
    Done
    Upgraded To ArubaInstant_Taurus_6.4.4.3-4.2.2 and boom!
    Its working
  • 6.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 20, 2016 09:40 AM
    Great :)
  • 7.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 04:43 PM
    I will try. Thanks. A wireshark capture when the client tries to connect? Is that?
  • 8.  RE: Ubuntu 16.04 error connecting to 802.1x
    Posted May 10, 2016 04:49 PM
    Could be Ubuntu error, since 16.04 is a recent release. Was working on ubuntu 14.04 and is working ok in windows and ios or android.
    I suspect that i need to accept a certificate but in 16.04 I only can put none or choose one CA Certificate that I don't have. Lets do more troubleshooting ;). Thanks
  • 9.  RE: Ubuntu 16.04 error connecting to 802.1x
