UCC No data found in controller
  • 1.  UCC No data found in controller
    Posted Mar 15, 2019 05:19 PM
    Good Afternoon,
    I have tow 7220 and one 7008 controllers, all using
    Software:
    6.5.4.2
    I was trying to set the UCC to capture the skype calls that is going in the offices, so far i read many articles and knowledge basses and i set the following settings:
    • Web Skype4B listening port: HTTP 15790
    • gmt Config profile "default-amp" (Predefined (changed))
      Parameter Value
      Stats Enabled
      Tag Enabled
      Sessions Enabled
      Monitored Info Enabled
      Misc Enabled
      Location Enabled
      UCC Monitoring Enabled
      AirGroup Info Disabled
      Inline DHCP stats Enabled
      Inline AP stats Enabled
      Inline Auth stats Enabled
      Inline DNS stats Enabled
    I rebooted the Controller after i completed the changes but still getting No Data Found in the UCC in Dashboard.
    Am I using the correct HTTP port?
    Is there any other settings that I am amissing here? Please advise.
    Thank you,
  • 2.  RE: UCC No data found in controller
    Posted Mar 15, 2019 06:38 PM
    Have you seen the Skype for Business Validated Reference Design guide here?  https://community.arubanetworks.com/t5/Validated-Reference-Design/Skype-for-Business-VRD/ta-p/508692
    If yes, what instructions there did you use to setup?
  • 3.  RE: UCC No data found in controller
    Posted Mar 18, 2019 11:56 PM
    Hi ,
    Yes i read this one, and many more, but still can't get it to work.
    some of those VRDs are similar, and others are different, but it all showing how helpfull is using the UCC to track the skype4B calls.
    also, it all showing a very simple steps to activate it:
    1- set Web Skype4B listening port to HTTP 15790
    2- configure the defualt-amp profile to enable UCC monitoring.
    3- create ACL to monitor the Lync calls, Permit TCP 443, and UDP 1024-65535
    we are using Lync online, and I have all that configured already.
    What i am missing here?
    Thank you,
  • 4.  RE: UCC No data found in controller
    Posted Mar 19, 2019 12:55 AM
    The web Skype4B listening port is only for sending SfB SDN data to the controller. Are you doing that?
  • 5.  RE: UCC No data found in controller
    Posted Mar 19, 2019 01:52 AM
    Thank you for the quick reply!
    No we don't use sfb SDN, so i removed that setting.
  • 6.  RE: UCC No data found in controller
    Posted Mar 19, 2019 11:42 AM
    I think removing that setting did the magic, i start getting the calls information. Thank you all for all your help!
  • 7.  RE: UCC No data found in controller
    Posted Mar 19, 2019 04:53 PM
    One more question!
    I have the RAP SSID is in tunnel mode, should i get the Skype4B calls that is using that SSID in UCC too?
    Thank you,
  • 8.  RE: UCC No data found in controller
    Posted Mar 19, 2019 06:27 PM
    Yes, in tunnel mode client traffic flows to the mobility controller for decryption/processing just like a typical campus AP, so should have the same visibility. The only difference in this case between a RAP and a Campus AP is that the tunnel between the AP and controller is also encrypted by an IPSec tunnel for the RAP, otherwise they are similar.
  • 9.  RE: UCC No data found in controller
    Posted Mar 20, 2019 05:50 PM
    Is it required to reboot the controller after enabling the UCC monitoring?
  • 10.  RE: UCC No data found in controller
    Posted Mar 26, 2019 05:24 PM
    No. Do you see any UCC dashboard information on the controller? Confirm that it's visible there before troubleshooting whether it's making it to Airwave.
