Hello TurboLuk,
We are glad to know that your problem is solved now.
However As per the programming guide2.3 [page 200 -201] Integrating Views to the SDN Controller GUI,
The second parameter (“com/hp/hm/ui”) of the super(…) call in the constructor of the UIExtension.java listing specifies the location of the two files the
framework uses to integrate the views: css.hml and js.html. These files act as links to the application’s cascading style sheets [41] and
the application’s JavaScript files respectively.
So it looks like while integrating views to the SDN Controller GUI that super(…) call was not correctly coded.
Please let us know what exactly you were trying to do.
HP SDN Team
