Wired Intelligent Edge
last person joined: 11 hours ago
UK power for 5400 series switch
  • 1.  UK power for 5400 series switch
    Posted Mar 20, 2019 03:18 PM
    Hi all,
    Probably a really obvious / simple question; but we have some 5406/5412 switch chassis. Some of the places I will be installing them only have 3 pin UK domestic grade power available. Can I plug 4 PSUs from the back of a big 5412 chassis straight into the 3 pin plug on the wall?
    I ideally will have UPS etc but worst case might only have domestic style power available.
    Will this be ok?
  • 2.  RE: UK power for 5400 series switch
    Posted Mar 20, 2019 08:00 PM
    Greetings!
    As long as you are using power cables with the proper connectors, and the circuit is properly rated for the switch in frequency (50 or 60 Hz), voltage (110-127 or 200-240 VAC), and current (will vary depending on switch power loading), this should work just fine.
  • 3.  RE: UK power for 5400 series switch
    Posted Mar 21, 2019 02:18 AM
