We upgraded from a 3200 with 6.1.4.1 to a 7210 with 6.2.0.2. The only issue is our RAP 3's and 5's will not work with the UML290 4g usb card. Has anyone has this issue?
I tried reprovisioning it with no luck.
What settings are you using?
Did they ever work on the older code?
Yes its worked fine on 6.1.3.4 and 6.1.4.1 using the instrustions from here.
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/RAP5-4G-UML290/m-p/32322
