UN-provisioing
  • 1.  UN-provisioing
    Posted Sep 27, 2012 11:48 AM
    I'm still new in Aruba land.  How do I un-provision an AP on a 3200XM so I can provision it on the backup controller?  Found lots of instruction on how to provision but not unprovision.
    Dennis
    #3200
  • 2.  RE: UN-provisioing
    Posted Sep 27, 2012 04:31 PM
    Just provision it to the new one. I usually move them around by using the Host Controller IP Address field on the AP provision page.
    I guess you could also completely reset the AP by using the console to do a clearenv. You can even tell it where to go when it boots next by using setenv commands directly to the AP console. But the first way should be just fine.
  • 3.  RE: UN-provisioing
    Posted Sep 27, 2012 07:18 PM
    Are you using redundancy or are you using master and local config?
    What do you mean with backup controller?
